Mass flow @outlet is greater than mass flow@inlet |
July 10, 2015, 06:03 |
Mayur Bhandari
Rep Power: 10 |
Hello dear all,
I am simulating a decanter (rotating frame). I have a boundary conditions are as @inlet mass flow rate is 4.16 kg/s and @outlet average static pressure is zero. After simulation in post-processing I found that @outlet mass flow rate is 4.45 kg/s which seems to be invalid. Please tell me that at most general, what would be the conditions for such mismatch situation? Does meshing affects? How? Please help me |
July 10, 2015, 06:19 |
Rep Power: 143 |
Assuming this is a steady state simulation where the inlet must balance the outlet: It means you are not adequately converged. Run the simulation for more time steps.
For transient simulations it is a bit more complex. |
July 10, 2015, 06:24 |
Mayur Bhandari
Rep Power: 10 |
Thank you for replying Ghorrocks.
Yes, It is steady state incompressible simulation. I gave 100 iteration. Should I gave some more hundred so that it will have good convergence? |
July 10, 2015, 06:26 |
Rep Power: 143 |
The residuals are what you should be watching to see if you are converged or not. And in this case as you have a problem with conservation I would use imbalances as well. You use as many iterations as are required to achieve the convergence you need.
July 10, 2015, 06:28 |
Mayur Bhandari
Rep Power: 10 |
ok thank you
Issues on the simulation of high-speed compressible flow within turbomachinery | dowlee | OpenFOAM Running, Solving & CFD | 11 | August 6, 2021 06:40 |
mass flow inlet and pressure outlet with target mass flow rate | Zigainer | FLUENT | 13 | October 26, 2018 05:58 |
Convergence problem with target mass flow rate | ADL | FLUENT | 2 | May 29, 2012 21:11 |
mass flow | Wenbin Song | FLUENT | 0 | September 27, 2005 13:00 |
Mass Flow Inlet | Pravir Kumar Rai | FLUENT | 0 | February 19, 2003 14:03 |
