July 22, 2015, 16:35 |
Where to change CFL number in CFX
Rep Power: 10 |
Hi everybody ,
I' m want to change the CFL number in CFX , both in a case for steady and a case for unsteady conditions. I wanted to ask where I can find the option to change the Courant number. Or I can maybe just change the deltat and the velocity ? Thank yoy |
July 22, 2015, 19:27 |
Rep Power: 143 |
CFX uses physical variables, so adjust the time step size to adjust the CFL number.
July 23, 2015, 07:10 |
Marcin
Rep Power: 12 |
on the expert parameters??
Quick Tips and Tricks, Tutorials FLuent/ CFX (CFD) https://howtooansys.blogspot.com/ |
July 23, 2015, 07:12 |
Rep Power: 143 |
No, there is no expert parameter for CFL. As I said, you adjust the CFL by setting the time step size.
You can use adaptive time stepping to home in on a Courant number. You can also define a CEL expression for the CFL number and use that to set the time step if you like. |
July 23, 2015, 09:24 |
Rep Power: 10 |
Thank you for your answers , but if I am working in steady (so no time step to choose) how can I change the deltat ? Should I change the time scalefactor ? In which way ?
Thanks , Trump |
July 23, 2015, 18:36 |
Rep Power: 143 |
If you are doing a steady state simulation then CFL does not apply.
But CFX uses a psuedo-transient approach to steady state convergence. So you still define a physical time step size. Local time scale factor is another approach CFX can do, but that is not generally recommended for most applications. |
foam-extend_3.1 decompose and pyfoam warning | shipman | OpenFOAM | 3 | July 24, 2014 08:14 |
How to get vertex(node) number in CFX user Fortran.. | flyply | CFX | 4 | February 4, 2014 19:51 |
decomposePar pointfield | flying | OpenFOAM Running, Solving & CFD | 28 | December 30, 2013 15:05 |
Stable boundaries | marcoymarc | CFX | 33 | March 13, 2013 06:39 |
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues | michele | OpenFOAM Meshing & Mesh Conversion | 2 | July 15, 2005 04:15 |
