July 24, 2015, 07:51 |
oscillating with accelerate
rasool
Rep Power: 13 |
hi
i want rotate and oscillate stirrer with this equation by sliding mesh: Vteta= C*sin(teta); C is constant how can apply this type of rotation on subdomain? stirrer is in a subdomain like picture. in past i rotate it with presented cel x=(x-Total Mesh Displacement X)*cos(2*pi/D*t)+(y-Total Mesh Displacement Y)*sin(2*pi/D*t) y=-(x-Total Mesh Displacement X)*sin(2*pi/D*t)+(y-Total Mesh Displacement Y)*cos(2*pi/D*t) but it has no accelerate or oscillate. |
July 24, 2015, 20:48 |
Rep Power: 143 |
I don't fully understand your question, but if the motion is purely rotational then consider using rotating frames of reference.
If you are using moving mesh then this sounds like just a rotation transform which you can find easily on the web. |
July 26, 2015, 03:15 |
Marcin
Rep Power: 12 |
can You try with immersed solid ??
That will be much easier
Quick Tips and Tricks, Tutorials FLuent/ CFX (CFD) https://howtooansys.blogspot.com/ |
What is "Lock-In" in oscillating cylinder problem? | 9mile | Main CFD Forum | 0 | June 3, 2015 09:57 |
Reason for oscillating residuals | fayaazhussain | Main CFD Forum | 3 | August 21, 2014 10:31 |
oscillating inlet | mo.houssami | OpenFOAM | 13 | January 16, 2013 08:00 |
[Other] Oscillating Airfoil and Independently Oscillating Flap | dancfd | OpenFOAM Meshing & Mesh Conversion | 3 | August 26, 2010 18:52 |
time averaged heat transfer in oscillating flow | Matthieu Ubas | Main CFD Forum | 2 | November 5, 1999 14:20 |
