July 30, 2015, 15:40 |
increase the mesh and change in results?
A.heydari
Rep Power: 10 |
Hello:
Why increase the mesh, the results are far from the reality? Of course, after every picture you can see, the results Especially in right side of semi-cylinder on the the experimental results distances! |
July 30, 2015, 15:46 |
Rep Power: 32 |
What do you mean by increasing the mesh ?
What are you increasing ? Your images from left to right are increasing the mesh element size, not the mesh element count. |
July 30, 2015, 16:22 |
A.heydari
Rep Power: 10 |
What is the difference between the element size and element count there? And what to do with my question?
July 30, 2015, 18:29 |
Rep Power: 143 |
I do not understand your question either. Can you write it again more clearly?
July 31, 2015, 01:09 |
A.heydari
Rep Power: 10 |
hi;
I have some exprimental data. After each of these conditions mesh changed .Data modeling has been compared with the results. In the next section of the half cylinder is not good results. And every time fine mesh results more Different. Why? What should I do? |
July 31, 2015, 01:15 |
Rep Power: 143 |
That means your mesh is not fine enough to achieve adequate mesh insensitivity. You need a finer mesh still. It is normal for the results to jump around when the mesh is way too coarse.
This assumes that the remainder of your simulation is correct, of course. |
July 31, 2015, 01:37 |
A.heydari
Rep Power: 10 |
Dear ghorrocks;
With the increase in the fine mesh model can be meshed together in the third dimension. While I'm a two-dimensional model. (1 mm thick two-dimensional model. The maximum length of 5 meters is my model). |
July 31, 2015, 01:43 |
Rep Power: 143 |
I do not understand your last comment.
Also flow over a cylinder has regimes where it is three dimensional. If you model a three dimensional flow with a two dimensional model you will get unpredictable results. Are you sure a two dimensional model is appropriate for the flow regime you are in? |
July 31, 2015, 01:58 |
A.heydari
Rep Power: 10 |
High time software solution, I decided to do a two-dimensional model. Is this wrong?
July 31, 2015, 02:32 |
Rep Power: 143 |
If you are saying you chose to do a two dimensional simulation of a three dimensional flow because the simulation time was too long - if you want an accurate answer then yes, that is wrong.
July 31, 2015, 02:48 |
#11 |
A.heydari
Rep Power: 10 |
Why wrong? More Info
Your suggestion to solve this problem? |
July 31, 2015, 02:50 |
#12 |
A.heydari
Rep Power: 10 |
July 31, 2015, 02:51 |
#13 |
Rep Power: 143 |
Desmond is right. If you change your flow conditions to one where it is a two dimensional flow (possibly by reducing the flow velocity) then you can do a two dimensional model. There are good results to compare against for this flow, so it is a good benchmark simulation to make sure you can do an accurate simulation before taking on the more difficult three dimensional simulation.
July 31, 2015, 03:01 |
#14 | ||
Rep Power: 143 |
July 31, 2015, 03:02 |
#15 |
A.heydari
Rep Power: 10 |
thanks alot
sliding mesh problem in CFX | Saima | CFX | 46 | September 11, 2021 07:38 |
Significant change in results with changing either mesh size or time step size. | nettpanic | FLUENT | 5 | October 24, 2014 02:37 |
[snappyHexMesh] Layers:problem with curvature | giulio.topazio | OpenFOAM Meshing & Mesh Conversion | 10 | August 22, 2012 09:03 |
Mesh sensitivity when using phase change models | BKaus | STAR-CCM+ | 0 | February 28, 2012 20:51 |
[Gmsh] 2D Mesh Generation Tutorial for GMSH | aeroslacker | OpenFOAM Meshing & Mesh Conversion | 12 | January 19, 2012 03:52 |
