August 6, 2015, 06:41 |
Equation for evaporation loads in pools
Piotr
I would like to insert into Ansys CFX Setup following equation for evaporation loads from the swimming pool: w = A/Y * (pw - pa) * (0.089 + 0.0782*V) where: w = evaporation of water, kg/s A = area of pool surface, m^2 Y = latent heat required to change water to vapor at surface water temperature, kJ/kg pw = saturation vapor pressure taken at surface water temperature, kPa pa = saturation pressure at room air dew point, kPa V = air velocity over water surface, m/s How can I take into consideration, eg. saturation pressure, which value depends on temperature value? I guess there is no variable or formula available for it in Ansys, so I have to prepare it by myself? If so, how can I do it? Formula refering to another formula? Thanks in advance for your answers! |
August 6, 2015, 18:46 |
Rep Power: 143 |
Your question is not a CFX question, it is general physics. I will leave it up to you to derive this formula as only you know what is appropriate for what you want to do. But implementing it in CFX as a mass source term should be straight forward once you have it.
mass flow in is not equal to mass flow out | saii | CFX | 12 | March 19, 2018 05:21 |
Some problem of "Qcriterion.mcr& | yuyuxuan | Tecplot | 9 | February 12, 2016 03:27 |
Derivation of Momentum Equation in Integral Form | Demonwolf | Main CFD Forum | 2 | October 29, 2009 19:53 |
Need help:about energy equation in CFX | Stein | CFX | 4 | July 2, 2009 22:31 |
Boundary conditions in a Poisson's equation? | vincent | Main CFD Forum | 4 | April 16, 1999 02:19 |
