Home > Forums > CFX
Large residual distributed at uniform flow region
Old   August 16, 2015, 23:10
Question Large residual distributed at uniform flow region
Anna Tian's Avatar
Meimei Wang
Anna Tian is on a distinguished road
As you can see in the attached pictures, the region with vortex doesnít have large residual over there but the region with quite uniform flow is distributed with large residual which causes convergence problem. Could anyone explain thatís why and how to solve this problem?
Best regards,
Meimei
Anna Tian is offline   Reply With Quote
Old   August 17, 2015, 02:54
ghorrocks is a jewel in the roughghorrocks is a jewel in the roughghorrocks is a jewel in the rough
You have very high aspect ratio elements in the wake region. It is always going to have a hard time resolving the wake when the elements are that long and skinny. You will need to reduce the aspect ratio of those elements.
Old   August 19, 2015, 00:45
Anna Tian's Avatar
Meimei Wang
I improve the aspect ratio over there but convergence doesnít become any better. I think coarsening the grids over the vortex region at the trailing edge is the general way to improve the convergence for this kind of problem (of course not too coarse).
Best regards,
Meimei
Old   August 19, 2015, 01:31
Refining the mesh results in less numerical dissipation which means the inherent instabilities in shear layers, wakes and similar features become more difficult to resolve. So yes, I would expect convergence to get more difficult as mesh size gets smaller.
Be careful coarsening the grid as you will be loosing accuracy by doing it. Make sure it is not a critical part of the flow, and do a sensitivity analysis on it to be sure.
Thread Tools
Trackbacks are On
Cannot run the code properly: very large time step continuity error crst15 OpenFOAM Running, Solving & CFD 9 December 14, 2014 19:17
a problem with convergence in buoyantSimpleFoam skuznet OpenFOAM Running, Solving & CFD 5 February 19, 2014 05:30
Courant-number explodes after a lon while (icoFoam) Rody- OpenFOAM Running, Solving & CFD 6 January 29, 2014 05:27
Unstabil Simulation with chtMultiRegionFoam mbay101 OpenFOAM Running, Solving & CFD 13 December 28, 2013 14:12
Unknown error sivakumar OpenFOAM Pre-Processing 9 September 9, 2008 12:53
