September 2, 2015, 10:54 |
NAME_MOD: Error finding variable "TSUPER"
Muhammad Umair
Rep Power: 10 |
Please tell me about this problem,,,, @ghorock... please explain,,, |
September 2, 2015, 11:13 |
Rep Power: 32 |
If you look into your ANSYS CFX installation directory, under the etc folder/directory, there is a file named VARIABLES with settings of many of the CFX variables.
If you look for TSUPER, you will find its user friendly name is Supercooling. I assume you must have an expression using the Supercooling. I also assume you are using the wall boiling model. Either you are missing a fluid prefix, such as MyFluid.Supercooling or you found a defect in the software and probably need to contact ANSYS CFX support for further help. |
September 2, 2015, 19:35 |
Muhammad Umair
Rep Power: 10 |
thanks opaque
OpenFoam-1.6-ext Allwmake compilation error - one last barrier | Pat84 | OpenFOAM Installation | 15 | July 25, 2012 21:49 |
emag beta feature: charge density | charlotte | CFX | 4 | March 22, 2011 09:14 |
error in COMSOL:'ERROR:6164 Duplicate Variable' | bhushas | COMSOL | 1 | May 30, 2008 04:35 |
Env variable not set | gruber2 | OpenFOAM Installation | 5 | December 30, 2005 04:27 |
Replace periodic by inlet-outlet pair | lego | CFX | 3 | November 5, 2002 20:09 |
