September 9, 2015, 19:42 |
Fatal error
Alvaro
CFX is good in my computer until I click SET UP, when this message appears: Fatal error The application has encountered an unexpected problem and will now terminate. Aborting due to unexpected error Application failed to conect SOMEONE CAN HELP ME PLEASE??? The details of the error are this: System.ApplicationException: Application failed to connect. at Ansys.CFX.Foundation.App.CUEApplicationProxy.Start (Boolean waitForCommands) at Ansys.CFX.CFXCore.App.CFXPreProxy.LoadApplication( ) at Ansys.CFX.Foundation.Data.CUESourceDataObject.Edit (IFullContext context, Boolean interactive) at Ansys.CFX.CFXCore.Commands.EditSetupCommand.Execut e(IFullContext context) at Ansys.Core.Commands.Concurrency.CommandWorkUnit.ex ecuteInContext(CommandContext subContext, IExecutionEngineCallback tracer) at Ansys.Core.Commands.Concurrency.BaseWorkUnit.doExe cute(IExecutionEngineCallback executionEngine, CommandContext subContext) at Ansys.Core.Commands.Concurrency.BaseWorkUnit.Execu te(IExecutionEngineCallback executionEngine, Boolean dontCatchExceptions) --- Ansys.Core.Commands.CommandFailedException: Application failed to connect. CommandName: CFX.EditSetup(Container="Setup") at Ansys.Core.Commands.CommandAsyncResult.Wait(Int32 milliSecondsTimeout, Boolean exitContext) at Ansys.Core.Commands.CommandAsyncResult.Wait() at Ansys.CFX.CFXCore.Commands.EditSetupCommand.Invoke AndWait(IProtectedContext context, DataContainerReference Container, Boolean Interactive) at Ansys.CFX.CFXCore.Commands.EditSetupGui.Invoke(Gui OperationContext context) at Ansys.UI.UIManager.<>c__DisplayClassb.<InvokeOpera tion>b__a() at Ansys.UI.UIManager.InvokeOperationCore(String pseudoname, OperationDelegate callback, Boolean allowOSMessages, Boolean coreTransaction) |
September 10, 2015, 02:03 |
Maxim
Rep Power: 12 |
that looks mean. 'Failed to connect'... maybe there's a problem with the license server?
September 10, 2015, 03:06 |
pkladisios
Rep Power: 10 |
I found this which might be relevant to you solution:
http://www.esss.com.br/suportecae/in...es/Page592.htm As it mentions "This problem is license related and often happens when the license server is located remotely." |
September 11, 2015, 01:24 |
Rep Power: 13 |
cant you look that up in the license server utility?
September 12, 2015, 05:37 |
Rep Power: 143 |
Workbench does sometimes make errors much harder to understand.
I would fire up CFX stand-alone and see if you get the licensing error there. At least in stand-alone mode it gives a clear error message when it fails to get a license. |
[OpenFOAM] an error in Calculator's equation | immortality | ParaView | 12 | June 29, 2021 00:10 |
[OpenFOAM.org] compile error in dynamicMesh and thermophysicalModels libraries | NickG | OpenFOAM Installation | 3 | December 30, 2019 00:21 |
[OpenFOAM.org] Compile OF 2.3 on Mac OS X .... the patch | gschaider | OpenFOAM Installation | 225 | August 25, 2015 19:43 |
Errors in UDF | shashank312 | Fluent UDF and Scheme Programming | 6 | May 30, 2013 20:30 |
Problem with compile the setParabolicInlet | ivanyao | OpenFOAM Running, Solving & CFD | 6 | September 5, 2008 20:50 |
