Home > Forums > CFX
Estimating Tmean in CFD post
Old   September 18, 2015, 06:43
Default Estimating Tmean in CFD post
mariam.sara is on a distinguished road
Hello I attempt to estimate Tm using CFD post which defined as illustrated at the image may somebody guide me how can I write this expression in CFD post?
mariam
mariam.sara is offline   Reply With Quote
Old   September 18, 2015, 07:58
Opaque is on a distinguished road
Your expression already assumes constant/uniform specific heat capacity, Cp. Therefore, you can use the standard CEL averaging functions.
Since Cp cancels out,
T_mean = massFlowAve(Temperature)@Locator
The next step is to define the Locator of interest. Perhaps you define a cut plane through the geometry, and use it to evaluate the expression.
Opaque is offline   Reply With Quote
Old   September 18, 2015, 08:19
Hello I draw a line through the geometry named it as Line 1 at section where x=0.7125 m from pipe inlet and wrote an expression as:
Tm=massFlowAve(Temperature)@Line 1
but when I press evaluate it give me the error below:
Error
Only geometries with surface data are allowed for calculating massFlowAve
what the problem???????
Old   September 18, 2015, 08:38
The message is very clear.. You want to evaluate an area integral on a line ? There is no cross section, or any area.
Old   September 18, 2015, 08:45
So what I can do to evaluate Tm along this line ? No idea else?
Old   September 18, 2015, 09:00
I think you need to better describe what you are trying to achieve.
The mean, ( or better known bulk) temperature is defined for a cross section of the flow and nothing else. What is your cross section of interest ? Perhaps you intend to plot the variation of the bulk temperature along a series of cross sections that follow some kind of line path.
To start, I would do the manual work. Create the cross section of interest, evaluate T_mean, create another one downstream, evaluate and confirm you are in the right direction. Then, you try to automate, simplify the effort.
Old   September 18, 2015, 09:05
Actually I am trying to evaluate Tm in order to estimate heat transfer coefficient from the relation:
h=heat flux/(Twall-Tbulk)
I have 2 D pipe geometry and want predict h at different axial locations I used Fluent for simulations just use CFD post for results
Old   September 18, 2015, 09:56
Antanas is on a distinguished road
Then your location is whole your domain.
Antanas is offline   Reply With Quote
Old   September 18, 2015, 10:45
No you wrong I want to compare my results with experimental work in it h predicted at selected sections from the pipe so predicting for the whole domain incorrect
Old   September 18, 2015, 12:41
And how they measured Tbulk?
Old   September 18, 2015, 14:20
They measured the bulk temperature at selected sections from the pipe currently I draw lines at these sections but do not know how to write expression in CFD post for it.
Old   September 18, 2015, 15:25
Why line? Anyway you can use areaAve or lengthAve or as Opaque wrote massFlowAve.
Old   September 19, 2015, 08:10
Yes I tried Opaque suggestion with massFlowAve but it give me error as illustrated at my previous post?
Old   September 19, 2015, 12:42
You tried it at a line, but you should use section plane.
Thread Tools
Trackbacks are On
CFD Design...The CFD Future John C. Chien Main CFD Forum 20 November 20, 2015 00:40
Problem regarding producing streamlines from surfaces in Ansys CFD post gauthamnarayan ANSYS 6 June 8, 2015 07:33
Problem regarding producing streamlines from surfaces in Ansys CFD post gauthamnarayan Visualization & Post-Processing 0 April 23, 2015 16:07
Post processing in CFD Post or Fluent. Blobs OpenFOAM Post-Processing 1 April 13, 2015 05:35
CFD Online Celebrates 20 Years Online jola Site News & Announcements 22 January 31, 2015 01:30
