ICEM CFD 10.0 cannot import Tecplot mesh!!!
Old   February 8, 2006, 12:15
Default ICEM CFD 10.0 cannot import Tecplot mesh!!!
yi
If I just use ICEM to import the binary sample file originially provided by Tecplot(*.plt), there is no problem. However, if I first load the sample file into Tecplot, then use the "write data" function in Tecplot to save the sample file in another name such as sample2.plt. Then this file cannot be importted into ICEM! What I get from ICEM is just an error message saying "cannot read the file".
Do you think there is a bug in ICEM 10.0? Did Ansys thoroughly test their "Tecplot Import Function" before they release it?
Old   February 13, 2006, 05:07
Default Re: ICEM CFD 10.0 cannot import Tecplot mesh!!!
KBanks
The problem you are describing sounds more like a Tecplot issue than an ICEM issue, since it works just fine until you change it in Tecplot and write it out again.
Old   September 30, 2015, 14:07
suryajagan77
suryajagan77 is on a distinguished road
Hi...
Have you got any solution of this problem ?
suryajagan77 is offline   Reply With Quote
[ICEM] Export unstructured periodic mesh from ICEM CFD to Fluent ivanddd ANSYS Meshing & Geometry 1 February 3, 2011 00:51
ICEM CFD to CFX geometry and mesh Luca CFX 6 February 4, 2010 16:31
Gambit mesh file import into ICEM CFD dev.... FLUENT 2 January 29, 2009 10:37
----------------2D mesh with ICEM CFD Abir FLUENT 2 September 12, 2008 23:55
icem: import tecplot mesh David CFX 4 August 9, 2006 08:30
