How to use ANSYS CFX to get the drag coefficient? |
September 24, 2005, 10:46 |
I used CFX to simulation a bluff body. CFX offers viscous force and pressure force,but it doesn't the coefficient. How can I get the coefficient of the bluff body? Please the master-hands help me! Thanks a lot!
September 24, 2005, 15:09 |
Re: How to use ANSYS CFX to get the drag coefficie
In CFX-Post you can obtain force_x()@Surface, force_y()@Surface and force_z()@Surface. If the velocity is aligned with the x-axis, you could obtain the drag coefficient as Cd = force_x()@Surface / (0.5*Rho*U^2*A) |
October 7, 2005, 08:13 |
Many thanks for you reply! Can you sent the tutorial of drag coefficient?
June 20, 2010, 07:05 |
Rep Power: 15 |
hi
to find drag coefficient, in the above formulae what is A, is A = length * width * 0.8 |
June 20, 2010, 07:22 |
Rep Power: 143 |
A is a representative area. For bluff bodies that is usually the frontal area by for airfoils they frequently use the planform area. Check you use the right area definition.
But this is very basic stuff which is dicussed in most introductory fluid mechanics books. Go to your library and look it up. |
January 23, 2012, 12:04 |
error help
Tom Walker
Rep Power: 14 |
I know this is quite an old post but I don't know where else to turn..
when I try and do force calculations in CFX i get an error message that says "Only geometries with surface data are allowed for calculating force" what does this mean and how do I generate surface data? Thanks Tom Walker |
January 23, 2012, 17:37 |
Rep Power: 143 |
It means exactly what it says - you can only calculate force on surfaces. You are trying to calculate force on a point, line or volume body and that is not meaningful.
January 23, 2012, 20:50 |
Tom Walker
Rep Power: 14 |
thank you very much, I can't believe I was over thinking it like that!
October 1, 2015, 02:45 |
#9 | |
N B Khan
Rep Power: 12 |
Sir, Kindly tell me how to monitor the value of Cd or Cl... In case of Fluent, we can monitor it and later on, we can also plot the graph of Cd vs time or Cl vs time.... but I am unable to monitor the Drag force or lift force on cylinder while using CFX... Please help |
October 1, 2015, 03:44 |
#10 | |
Rep Power: 18 |
October 1, 2015, 04:58 |
#11 | |
N B Khan
Rep Power: 12 |
I tried to make the expression as show in image... In CEL, I couldnt find the exact way to write formula.. In my case Vel=0.034m/s density=1.185kg/m^3 Projected Area=0.02m^2 Drag forces are in x direction ACtually Even in writing formula in EXPRESSION, it is not possible to separate Force in x and y component for Drag and lift coefficient respectively. |
October 1, 2015, 06:12 |
#12 | |
Rep Power: 18 |
2. You should write values along with their dimensions in square brackets. 3. You may use variables names to access their values. Your CEL for Cd may look like that: Code:
2*force_x()@Cylinder / (Projected Area*massFlowAve(Density)@inlet *(massFlowAve(Velocity)@inlet)^2) |
October 1, 2015, 06:30 |
#13 | |
N B Khan
Rep Power: 12 |
I did it... Thank you again... Actually, In post CFD, there is "force_x" term available while write the formula in EXPRESSION...but in CFX pre, there is only term "force ()@region..."...so I was bit confused how to insert "force_x" component... but now i simply write manually "_x" in available term " force ()@region"... |
Display Modes | |
drag coefficient in ansys fluent 12.0 | krishna | FLUENT | 19 | April 12, 2018 01:49 |
Incorrect Drag and Drag Coefficient for flow over a cylinder | ozzythewise | Main CFD Forum | 8 | June 13, 2012 07:24 |
FSI using CFX and ANSYS | Bi Chang | CFX | 2 | May 10, 2005 05:47 |
ANSYS to acquire CFX | Fred | FLUENT | 0 | February 18, 2003 22:04 |
ANSYS to acquire CFX | Fred | Siemens | 0 | February 18, 2003 22:03 |
