Expert parameters
Like Tree2Likes
  • 1 Post By Lance
  • 1 Post By Lance
Old   October 27, 2015, 01:19
Question Expert parameters
alirezame is on a distinguished road
I would appreciate if you could inform me how can I change properties interpolation option in CFX pre v16.0
I found in solver guide:
EXPERT PARAMETER:
prop interp option = 1, 2 (default), or 3
END
but this option is not in expert parameters of solver tab. how can I add this.
Many thanks in advance
alirezame is offline   Reply With Quote
Old   October 27, 2015, 01:28
Lance
Lance is on a distinguished road
Right click on expert parameters, edit in command editor, copy/paste the text you need.
But be sure to know what you are doing.
alirezame likes this.
Lance is offline   Reply With Quote
Old   October 27, 2015, 01:36
Question
Many thanks for your fast response.
I did that, but now I get this error once the solver starts to run.
Error: Sub-object 'EXPERT PARAMETERS' is not allowed in /
Old   October 27, 2015, 02:44
Lance
You probably copied the text into the wrong place.
One easy way to get the parameter where you want it is to go to expert parameters in the gui, set solve fluids = t (default value), then right click expert parameters/edit in command editor. Find solve fluids = t, and replace with your expert parameter.
Old   October 27, 2015, 02:55
Thumbs up
Many thanks for your help. it works.
Pro/E to ANSYS Parameterization Guide Trues ANSYS 4 April 18, 2018 05:52
results on wall force (expert parameters) syafiq CFX 1 October 5, 2011 05:35
signicance of 'htc for tbulk' in expert parameters sachin CFX 1 January 26, 2009 16:59
expert parameters of SST model? David CFX 1 December 2, 2005 06:36
Expert Parameters: Can you use a variable? Paul CFX 1 July 6, 2005 15:21
