October 27, 2015, 01:37 |
Fan air flow in a container
darker
Rep Power: 10 |
I am currently doing a analysis on the fan air flow in a container. However, i am unable to set up the convection flow of the fan. My goal is to achieve maximum suction pressure of the fan in the container.
My questions are: 1)Since my fan is inside a container what domain do i select? (Solid domain or porous domain or Immersed domain)? i am using a computer fan. my design computer fan is surrounded by a fan casing followed by enclosed in a nozzle region. Almost like a plane engine |
October 27, 2015, 07:22 |
Rep Power: 143 |
Have a look at the example tutorials which come with CFX. You will find, of your options solid domain, porous or immersed solid - the answer is "none of the above".
The fan is modelled as a cavity in the fluid domain. And the fluid domain is probably in a rotating frame of reference. |
October 27, 2015, 09:03 |
darker
Rep Power: 10 |
does this includes the nozzle also be classified as fluid domain?
October 27, 2015, 17:53 |
Rep Power: 143 |
Most people are interested in what the fluid flow is doing. So if the nozzle contributes to the fluid flow then yes, you model it (that is the fluid domain inside the nozzle, not the nozzle itself).
Display Modes | |
high velocity reverse flow of air from outlet towards inlet | ranjitjdesai | Fluent Multiphase | 1 | August 23, 2018 03:27 |
Modeling the fan with a mass flow interface | saisanthoshm88 | CFX | 6 | August 1, 2014 07:11 |
analyzing the temperature of fliud (air) flow inside an underground duct. | arshbunny | CFX | 9 | April 3, 2014 09:52 |
Forced Convection: 2D fan (forced air flow source) | acdc_cfd | FLUENT | 0 | March 17, 2014 09:34 |
Radiation interface | hinca | CFX | 15 | January 26, 2014 18:11 |
