November 9, 2015, 22:43 |
Thruster Wash Effect
Hi All,
I would like to model the effectiveness of a tugboat pulling on the side of a large ship. At the end of the day, I would like to produce a graph of the net force exerted on the ship (assuming they are connected by a rope), vs the distance away from the ship. I imagine a very simple model of a large, rectangular object (ship) extending well below the free surface, and a cylindrical subdomain, a distance from the side of the "ship" (the axis pointing towards the ship, at right-angles), a couple of metres below the surface. The cylindrical subdomain is to model the thruster of the tug, using a momentum source. The tug boat can produce a bollard pull of, say 10T. Depending on the distance away from the ship's side, the wash of the thruster will produce a force on the ship, countering the pull from the rope, eg 2T, which I will monitor from the output. There will then be a net force acting on the ship (8T). This is the quantity that I am after. I intend to put in an axial momentum source of 10,000kg x 9.8m/s/s divided by the Volume of subdomain m^3 Some other bits of info: Free surface model Thruster diameter 1.6m Thruster distance from ship 2-20m Ship draft 12m Ship length - many metres. Am I over simplifying things here? The main thing I'm counting on is dissipation of the momentum over a distance. Awaiting incoming... |
modelling the effect of smear effect in Casing with Drilling | babak1 | Main CFD Forum | 0 | July 17, 2013 10:48 |
Can Flow-3D solve the Joule-Thomson effect? | seasoul | FLOW-3D | 8 | December 21, 2011 00:01 |
Can 'shock waves' occur in viscous fluid flows? | diaw | Main CFD Forum | 104 | February 16, 2006 05:44 |
VOF and strong surface tension effect | phsieh2005 | Main CFD Forum | 1 | August 30, 2005 06:56 |
Iclude particle diameter effect in wall? | yueroo | FLUENT | 0 | April 14, 2001 03:56 |
