Expression: Should dimensions be included? And should spaces be used? |
November 10, 2015, 15:17 |
sadjad
Rep Power: 10 |
Hi
In CFX , when we write an expression, do need dimension is written? for example : Den*g*(0.5[m] -y) or 1000 [kg m^-3] And need locate or put SPACE between values and dimension or not? for example : Den*g*(0.5[m] -y) or 1000 [kg m^-3] what mines [.....] How write an expression? |
November 10, 2015, 16:48 |
Rep Power: 32 |
Let us say this is your expression set
LIBRARY: CEL: EXPRESSIONS: MyDen = 1000 [kg m^-3] MyBuoyForce = MyDen * ( 0.5 [m] - y ) * g END END END Keep in mind that a given expression, such as MyDen, it is not only the value but its dimension as well; therefore, when you reference it somewhere else you only refer the variable name and not its components (value or dimensions) |
November 10, 2015, 22:08 |
sadjad
Rep Power: 10 |
Thanks Opaque.
My expression is according below but it dosnt answer me : What is my error? Den : 1000 [kg m^-3] InPress : Den*g*(0.5[m] -y) WaterX : 1 [m] AirVF : Step((x-WaterX)/1[m]) WaterVF : 1-AirVF and , in Global Initialization > Fluid Settings , when type "WaterVF" or "AirVF" ,cfx give me error and wants numerical value and dosnt accept "WaterVF" or "AirVF" |
November 12, 2015, 14:13 |
#4 | |
Rep Power: 18 |
November 16, 2015, 02:42 |
sadjad
Rep Power: 10 |
my range of x=1 m
November 16, 2015, 08:57 |
Rep Power: 32 |
Your example uses : instead of =. Is that correct ?
November 16, 2015, 15:53 |
sadjad
Rep Power: 10 |
my x value is 1
ok ? |
November 17, 2015, 07:45 |
Rep Power: 18 |
