Double meshing while piecing together a workbench through files folder? |
January 16, 2016, 15:57 |
Rep Power: 10 |
Long story short - my wbpj is corrupted (computer froze in the middle of a save, and I power shut it down, turned it back on, now the wbpj just has a basic hex error).
Good news though, the files folder is fine. Now, I would like to duplicate one of the blocks I had (with the geometry, mesh, setup, solution, and run) so I can duplicate, make tweaks to the geometry (move a fan a foot up etc). Procedure - I rename the meshdb file to a meshdat, import that from workbench screen (gives a geo-mesh block). Now, I drag and drop a cfx block on to the mesh of the above block. Now, I import the cfx file into the setup of the cfx block. I right click and update the mesh. I start a run using my previous run's .res file as an initialization. I get isolated fluid domains. I discovered the reason - I am getting two meshes - one from the initial meshdat drag-drop and another from the cfx import. Now, in the setup I cant delete the mesh I should (the one with the locations with a "2" in the front). So I delete, the other mesh (from the cfx file), but that throws all my interfaces domains off because they dont have a "2" in their locations. How do I delete the second mesh from this whole import procedure? |
January 18, 2016, 05:27 |
Rep Power: 14 |
How about reallocating the interfaces to the "2" locations if the whole mesh delete does not work as you intended?
January 18, 2016, 09:39 |
Rep Power: 10 |
Kinda dont want to do that. There are a LOT of interfaces...
January 18, 2016, 09:52 |
Rep Power: 14 |
That's what I suspected
And when using the "Edit in Command Editor" for your Interfaces?Maybe the renaming is a little easier? |
[Gmsh] Vertex numbering is dense | KateEisenhower | OpenFOAM Meshing & Mesh Conversion | 7 | August 3, 2015 10:49 |
wired error in openfoam | conceptone | OpenFOAM | 4 | August 7, 2012 15:45 |
Linux vs PC Compiling | Rhyno466 | Fluent UDF and Scheme Programming | 10 | May 11, 2012 17:01 |
Meshing locks workbench window. | andy2o | CFX | 0 | February 1, 2008 05:01 |
ICEM 5.0 - double meshing | Joan | CFX | 0 | November 7, 2004 06:09 |
