January 21, 2016, 11:01 |
phase change of R12
Amar
Rep Power: 10 |
i want to simulate the phase change of freon R12 from liquid to vapor
the total length is 1 meter , the liquid length was 600 mm and length of vapor phase was 400 mm i want to keep the temperature remain constant along liquid length (i.e, along 600 mm) and then decrease gradually how can i make this relation thanks in advance |
January 21, 2016, 17:07 |
Rep Power: 143 |
You have to set the flow conditions up so the fluid does this. Whatever the device is you are modelling will show you what you need to have to get this condition.
January 23, 2016, 00:52 |
Amar
Rep Power: 10 |
how can i do this conditions (up )
where it is found in ansys cfx |
simulation of phase change material melting | rosol | FLUENT | 4 | December 8, 2015 07:56 |
homogeneous free surface flow with phase change. | Niru | CFX | 13 | December 26, 2013 10:27 |
Two phase flow with phase change | Ahmad Al-Zoubi | CFX | 1 | November 26, 2008 03:59 |
Solid Phase change material | qiulan | Siemens | 0 | June 5, 2006 15:30 |
How to model the solid-fluid phase change in CFX | ohrmond | CFX | 2 | May 26, 2006 06:27 |
