Home > Forums > CFX
Define length parameter by CFX-Pre Expression
Old   February 1, 2016, 04:53
Default Define length parameter by CFX-Pre Expression
leasken is on a distinguished road
Hello, I am trying to define the hydraulic diameter for a channel flow by using an expression in CFX-Pre but cannot figure out how to properly implement it. Tried with
maxVal(y)@inlet - minVal(y)@inlet
but it resulted in the following error message:
ERROR
Attempt to evaluate the CEL callback function 'maxVal'.
Although it is valid to create an expression that
uses such a function, the preprocessor does not support
its evaluation.
I want to use a general expression and utilize the domain in CFX-Pre somehow. Any suggestions?
leasken is offline   Reply With Quote
Old   February 1, 2016, 05:19
Lance
Lance is on a distinguished road
Originally Posted by leasken View Post
the preprocessor does not support its evaluation.
Have you tried running the simulation anyway? Even though cfx-pre cannot evaluate the expression, the solver might be able to do it.
Lance is offline   Reply With Quote
Old   February 1, 2016, 05:42
I cannot start the solver with this expression, CFX-Pre tells me that
The function 'maxVal' referenced by parameter 'Normal Speed' in object '/FLOW:Flow Analysis 1/DOMAIN: Default Domain/BOUNDARY:inlet/BOUNDARY CONDITIONS/MASS AND MOMENTUM' has a disallowed argument, 'y'. The solver does not support the use of this variable in this context.
Old   February 1, 2016, 06:51
honcho62 is on a distinguished road
I think your problem is that you're requesting the maximum value of a singular scalar. So it's kinda pointless in the sense that y is both its min and max value. You're better off defining a line along the vertical edge and then saying maxValue(velocity u)@line for instance.
honcho62 is offline   Reply With Quote
Old   February 1, 2016, 07:58
ghorrocks is a jewel in the roughghorrocks is a jewel in the roughghorrocks is a jewel in the rough
honcho: I do not think that is correct. The original expression is asking for the max and min values of the y nodal locations on the boundary patch labelled inlet. This sounds valid to me. I am confused about the problems Martin is reporting with his expression as I have used very similar expressions to this (max/min values of xyz nodal values on boundary patches) before and have not had any problems with it.
Old   February 1, 2016, 08:11
Yes, I have also used a similar expression for calculating the length of an Iso Clip in CFD-Post. Thought that I could use the same here, but nope..
Old   February 2, 2016, 05:46
Michael Shives
mrshives is on a distinguished road
I've had a similar, frustrating problem. It's a hack solution... but you could try creating an additional variable called "myY" (set to equal "y" using an expression) then use "myY" in your minVal and maxVal functions. ... sometimes cfx just behaves badly....
Also don't worry about the pre-processor not supporting the function... that's just a warning, the real question is whether the solver supports that function (and I think the answer is yes)
mrshives is offline   Reply With Quote
Old   February 2, 2016, 07:57
No progress.. The warning issued stops CFX-Pre from creating a .def-file and no simulation can then be run.
I tried a bit with your hack solution, but not sure on how to define the "myY"-expression, any suggestions? Now I tried creating the expression "myY" and defining it as y, and also something like y@inlet, but nothing..
Old   February 8, 2016, 02:55
So I tried to solve this problem using parameters. I created an expression "Dh" and assigned a value to it. I ran a simulation and in CFD-post I selected "Use as Workbench Input Parameter". In the Parameter Set I changed the definition of Dh from the value "0.005 [m]" to an expression using two other input parameters, so basically
P1 H 5
P2 W 5
P3 Dh 2*(P1*P2)/(P16+P18)
But then there's no unit assigned to P3 and Workbench complains about it. P1 and P2 are parameters from my CAD-file, where I have constructed H and W as expressions in the CAD software, imported the geometry to Workbench and enabled the parameters under CAD-parameters in the Mesh module. When P1 and P2 are enabled and appear in my Parameter Set, there is no unit assigned to them so P3 is dimensionless. When I just try to add [mm] after P1 and P2 in P3:
P3 Dh 2*(P1[mm]*P2[mm])/(P16[mm]+P18[mm])
Workbench says "Name 'P1_Q' is not defined." in both the Value and Unit box for P3. Rather frustrating. What am I missing or doing wrong?
Old   February 8, 2016, 06:20
P1 H 5
P2 W 5
Fixed it... Multiplied by 1 [mm].
P3 Dh (2*(P16*P18)/(P16+P18))*1[mm].
Thread Tools
Trackbacks are On
Molar fraction in CFX Pre expression Niekjuh CFX 4 July 14, 2016 19:11
Accessing cell values (CFX Pre and CFX Post) brahmarishiraj CFX 14 June 24, 2014 19:12
REAL GAS UDF brian FLUENT 6 September 11, 2006 08:23
Free surface boudary conditions with SOLA-VOF Fan Main CFD Forum 10 September 9, 2006 12:24
UDF FOR UNSTEADY TIME STEP mayur FLUENT 3 August 9, 2006 10:19
