Expression for uniform flow
Old   February 10, 2016, 11:08
Default Expression for uniform flow
Arjun Brueck
ABrueck is on a distinguished road
I'm modelling an exotic diffusor with high opening angle.
Within a parametric study I want wo find a configuration with the most uniform velocity profile at the outlet of the diffusor.
To compare different configurations, I thought about something like standard deviation and tried 'areaave(velocity.diversity)@<location>' as an expression, but I get [s^-1] as a dimension whereas I expected a dimensionless result.
In the CFX-Refernce Guide I do not finde any documentation for the velocity.<subexpressions>.
So the question is: Is there a Ansys expression to get the unifomity of the veolocity profile or do I have have to do the job with an external program?
I'm using Ansys 13
Thank you for any answer,
Kind regards,
Arjun
ABrueck is offline   Reply With Quote
Old   February 10, 2016, 17:31
I don't know if this will work, but can you do something like:
rmsAve((u-areaAve(u)@location)@location
Old   February 10, 2016, 21:05
Opaque will become famous soon enough
Keep in mind that such expression may only work in CFD-Post.
In the ANSYS CFX Solver, you must split the expression in parts such as
Create an algebraic additional boundary only variable,
MyBdyAV = u - areaAve(u)@location
MyUniformity = rmsAve(MyBdyAV)@location
Hope Glenn's suggestion works for you on either the solver, or post.
Opaque is offline   Reply With Quote
transient, impregnating flow problem fgommer FLUENT 0 February 29, 2012 16:10
Non-steady flow simplified for use in Vissim steamerandy Main CFD Forum 0 October 31, 2011 21:08
Flow meter Design CD adapco Group Marketing Siemens 3 June 21, 2011 08:33
CGNS lib and Fortran compiler manaliac Main CFD Forum 2 November 29, 2010 06:25
potential flow vs. Euler flow curious ... Main CFD Forum 23 July 21, 2006 07:40
