February 10, 2016, 15:25 |
Impeller Design
swapna
Rep Power: 10 |
Hello all,
I'm working on a mixed flow impeller. I used bladegen for blade profile and then used CFX turbo mode. Following conditions were used 1. Inlet BC : Pressure at 1 atm 2. Outlet BC : Mass flow rate - known 3. Using counter rotating walls for blade,hub and shroud resulted in errors. for what should I counter rotating wall ? |
February 10, 2016, 17:16 |
Rep Power: 143 |
Counter rotating walls are walls in a rotating reference frame which rotate against the rotating frame to end up being stationary in the stationary frame of reference.
So for bits of your model which rotate (eg blades) you do not want these counter rotating. Just leave these as stationary walls (relative to the rotating frame of reference). |
February 11, 2016, 11:22 |
swapna
Rep Power: 10 |
Thank you Glenn
I continued the simulations using blade,hub and shroud as no slip walls. I got a total efficiency in to out as 78.685 %. Now I wanna add a stator/diffuser to it. Is it possible to add both impeller and diffuser in ansys itself without building a CAD model in solidworks or Creo ? |
February 11, 2016, 14:44 |
Rep Power: 16 |
WB > BladeGen > TG > CFX > Import both meshes
Centrifugal Pump Impeller design | invincible328 | Main CFD Forum | 27 | September 21, 2014 10:59 |
3D impeller design for use in CFD model of CSTR | TATA | Main CFD Forum | 0 | November 22, 2011 13:19 |
impeller design | vidhya | ANSYS Meshing & Geometry | 0 | January 17, 2011 06:56 |
Info: Short Course On Thermal Design of Electronic Equipment | Arnold Free | Main CFD Forum | 0 | August 10, 1999 10:18 |
CFD - Trends and Perspectives | Jonas Larsson | Main CFD Forum | 16 | August 7, 1998 16:27 |
