March 14, 2016, 15:09 |
improve mesh
Julia C
Rep Power: 10 |
I want to simulate the flow in a hydro power plant. Before simulating a water hammer i want to make a steady simulation.
The problem is that my simulation does not converge. I think the reason is the poor mesh. When running the simulation the mesh statistic is quite bad. but i dont know how to improve it. I tried to make the mesh more fine specially in the regions where losses will occure. I wanted to make a hex mesh instead of a tri but since i have to consider inflation layers it doesnt work. +--------------------------------------------------------------------+ | Mesh Statistics | +--------------------------------------------------------------------+ | Domain Name | Orthog. Angle | Exp. Factor | Aspect Ratio | +----------------------+---------------+--------------+--------------+ | | Minimum [deg] | Maximum | Maximum | +----------------------+---------------+--------------+--------------+ | steady | 18.2 ! | 357 ! | 747 OK | +----------------------+---------------+--------------+--------------+ | | %! %ok %OK | %! %ok %OK | %! %ok %OK | +----------------------+---------------+--------------+--------------+ | steady | <1 6 94 | 1 11 88 | 0 0 100 | +----------------------+---------------+--------------+--------------+ Domain Name : steady Total Number of Nodes = 161952 Total Number of Elements = 430410 Total Number of Tetrahedrons = 225410 Total Number of Prisms = 205000 Total Number of Faces = 70274 Does anyone have an idea how i can solve this problem ? Thanks in advance |
March 14, 2016, 15:25 |
Julia C
Rep Power: 10 |
... the mesh
March 14, 2016, 16:16 |
Rep Power: 13 |
maybe you can make several bodies and give them each a different mesh?
But I guess its more some boundary conditions, when it does not converge. |
March 14, 2016, 20:53 |
Rep Power: 143 |
Geometries like this (big regions connected to long thin pipes) need to be meshed very carefully. I recommend you use a multibody part so you can do sweep meshes in the long pipe regions, with high aspect ratio elements to reduce the element count. On the large regions you can use normal meshing technqiues.
March 15, 2016, 03:11 |
Julia C
Rep Power: 10 |
Thanks a lot for your answer. But how can I make an inflation when i use the sweep-method ? |
March 15, 2016, 03:19 |
Rep Power: 10 |
You could try using MultiZone and then inflating that method, that works very well for structured meshes with inflation.
decomposePar problem: Cell 0contains face labels out of range | vaina74 | OpenFOAM Pre-Processing | 37 | July 20, 2020 05:38 |
[snappyHexMesh] Multi Region Mesh of a car filter | Zephiro88 | OpenFOAM Meshing & Mesh Conversion | 3 | September 11, 2019 19:34 |
Mesh motion with Translation & Rotation | Doginal | CFX | 2 | January 12, 2014 06:21 |
[ICEM] Generating Mesh for STL Car in Windtunnel Simulation | tommymoose | ANSYS Meshing & Geometry | 48 | April 15, 2013 04:24 |
[Gmsh] 2D Mesh Generation Tutorial for GMSH | aeroslacker | OpenFOAM Meshing & Mesh Conversion | 12 | January 19, 2012 03:52 |
