Turbulence length scale and integral length scale
Old   September 10, 2009, 04:58
Default Turbulence length scale and integral length scale
Yang Zhang
rizhang is on a distinguished road
Hi, everyone:
I have a question about turbulence length scale and integral length scale.
I am right now doing a CFD simulation about Wind Turbine by using CFX with kappa-Omega 2-Equation turbulence model. In order to specify the turbulence level at the inlet (about 20% turbulence intensity ), i need to give the value of turbulence length scale and turbulence kinetic energy. But, i just know the intergral length scale at the inlet which is equal the chord length of the blade. How can i convert the integral length scale into turbulence length scale.
Another method is that i can give the value of kinetic energy (kappa) and turbulence frequency (Omega). But, in order to calculate the omega, i need to know eddy viscosity ratio. Dose anyone know the eddy viscosity ratio of water at temperature 20° C?
Thank you very much
regards
yang
PS: i am using kappa-omega model and with very high turbulence level (20%)
rizhang is offline   Reply With Quote
Old   September 10, 2009, 06:38
Get yourself a copy of "Turbulence modelling for CFD" by Wilcox. That will explain where all these terms come from.
This is a function of the local turbulence conditions, not a material property. A value of 10 or 100 is often used when you have no idea but that is nothing more than a guess of a value in the typical range.
Old   April 22, 2016, 07:22
Default Filter-based turbulence model (FBM)
ahmed bel hadj taher
ahmed.enit is on a distinguished road
The filter size is set to values which are smaller than the length scales returned by the conventional RANS models. Specifically, the level of the turbulent viscosity is corrected by comparing the turbulence length scale and the filter size Δ, which is based on the local meshing spacing:
μt_FBM= ((Cμ*ρm*k^2)/ε)*f_FBM with f_FBM= min(1,(∆.ε)/k^(3/2) )
with ∆=max(∆_present,∆_grid)
my question is about the variables in CFX that can be introduced in place of ∆_present and ∆_grid
thank you
ahmed.enit is offline   Reply With Quote
Integral Length Scale vs Turbulent Length Scale Scott Nordsen FLUENT 2 January 20, 2014 01:17
estimation of integral time scale Clementine FLUENT 0 February 28, 2008 11:29
LES inlet length scale f.neilson Main CFD Forum 0 January 31, 2005 13:26
Von Karman Integral Length Scale Txingurri Main CFD Forum 0 May 2, 2002 12:05
Turbulence integral lengthscale and mixing-length Ray Main CFD Forum 1 September 12, 2001 19:51
