April 12, 2016, 08:02 |
error after 10th iteration
yaseen
Rep Power: 10 |
hello every one
I simulated free surface over spillway, before I run several trial there is no problem but now the problem of overflow floating point arise. note my mesh quality is good and physical set up is correct as trials before. I read the discussion in CFX faq about overflow point but I can solve mu prob. here is my CCL file is there is any mistake in it. thanks http://www.cfd-online.com/Forums/att...1&d=1460462368 http://www.cfd-online.com/Forums/att...1&d=1460462385 https://drive.google.com/open?id=0B3...S02cGJlejBOcUE |
April 12, 2016, 08:34 |
Rep Power: 143 |
Make it save some backup files before it crashes. Have a close look at them for unrealistic conditions. Have a very close look at the backup file from just before it crashes. What happened just before it crashed? Very often this is when a surface wave reaches a boundary.
April 12, 2016, 10:06 |
#3 | |
yaseen
Rep Power: 10 |
I only saw error in solver maneger, is there any way to see them? how? |
April 12, 2016, 20:45 |
Rep Power: 143 |
Make a backup file before it crashes and look at it in CFD_Post.
April 13, 2016, 10:30 |
yaseen
Rep Power: 10 |
But in my case there is no results created so, the CFD post does not active
April 13, 2016, 18:38 |
Rep Power: 143 |
Make a backup file *BEFORE* it crashes.
April 19, 2016, 14:22 |
yaseen
Rep Power: 10 |
April 19, 2016, 18:37 |
Rep Power: 143 |
If it has run for 10 iterations you can produce a backup file.
In CFX-Pre go to the output tab and select backup files. Change the frequency to each iteration. Then rerun the simulation and you should get 9 backup files before it crashes. To load these files in CFD-Post you have to go to the temporary directory (it will be a directory starting with a "."). |
April 20, 2016, 02:09 |
#9 |
Maxim
Rep Power: 12 |
Or you can create a backup file manually by clicking on the 'disk'-symbol in the solver manager (Ctrl+B). But both ghorrocks method and the one I just described are in the documentation. Maybe have a look?
April 20, 2016, 10:53 |
#10 |
yaseen
Rep Power: 10 |
thanks
I created buck up file, and a folder after saving was increased but how this file become open I tried in CFD post from file load result open file within the buck up folder, but I didnot see anything about how to solve this problem which prevent running |
GPU - GeForce GTX Titan Black? | frode86 | Hardware | 11 | August 8, 2016 22:36 |
Floating point exception error | lpz_michele | OpenFOAM Running, Solving & CFD | 53 | October 19, 2015 02:50 |
Hardware-Configuration for Fluent HPC-Pack (8x) | JohHaas | Hardware | 9 | March 3, 2015 13:25 |
Parallel runs slower with MTU=9000 than MTU=1500 | Javier Larrondo | FLUENT | 0 | October 28, 2007 22:30 |
Heat exchanger problem | chiseung | FLUENT | 16 | October 20, 2001 04:36 |
