April 15, 2016, 05:16 |
fatal overflow in linear solver
Aja
Rep Power: 14 |
I am simulating turbine. First, I ran with 448505 cells and results a. lls, there is the following error, Why? turbulence model is K-e scalable. Analysis type is steady. Thanks for your help. Last edited by aja1345; April 18, 2016 at 09:51. |
April 15, 2016, 05:57 |
Maxim
Rep Power: 12 |
This is an FAQ: http://www.cfd-online.com/Wiki/Ansys...do_about_it.3F
April 15, 2016, 07:30 |
Aja
Rep Power: 14 |
Thanks.
According the following text, What is the exact meaning of "time step"? Time step is about unsteady solution. right? or is time scale??
April 15, 2016, 07:39 |
Maxim
Rep Power: 12 |
yes, in a steady-state simulation it's timescale. Are you using auto timescale? Try different factors. Like 0.1, 1, 10, 100.
I've never used k-e scalable. So I don't know if any restrictions apply with this model. Maybe worth to check. Why aren't you using SST? It's the standard model for CFX and F. Menter, inventor of this model, works with Ansys - so that model should work the best |
April 15, 2016, 17:11 |
#5 | |
Aja
Rep Power: 14 |
According to your statement, I used auto timescale and I change value of factor and also i used physical timescale, but there is the Error!!! I think that mesh quality is good. But about initial condition, I set options according ANSYS CFX 15.0 Documentation. I have not enough other information about intial condition. i set this case as follows: For example, I had changed value of physical timescale to 0.1, but there is error in outer loop 12 as follows: About SSt model, I performed with sst, but again there is previous problem! Thanks for your guidance. Best. Aja Last edited by aja1345; April 18, 2016 at 09:52. |
April 16, 2016, 06:33 |
Rep Power: 143 |
It is not an error, it is a warning. See this FAQ: http://www.cfd-online.com/Wiki/Ansys...f_an_OUTLET.22
Also - refining the mesh makes convergence harder, not easier. You should expect more problems getting convergence as you refine the mesh. |
April 16, 2016, 07:32 |
#7 | |
Aja
Rep Power: 14 |
But when this massage appears, solution diverges!!! I read FAQ: http://www.cfd-online.com/Wiki/Ansys...do_about_it.3F I have one question about above link: Is opening type boundary condition can be placed from the beginning in outlet? In CFX documentation and the tutorial examples,it is not explained about this warning messages completely!! How do I solve this case?? I am grateful that guide me more. Thanks. Last edited by aja1345; April 16, 2016 at 14:20. |
April 16, 2016, 07:47 |
Rep Power: 143 |
The best approach when you get the "a wall has been placed..." warning is to move the outlet further downstream so that the recirculation does not hit it and the flow is all in the forwards direction. If this is not possible then replace it with an opening. And in some cases you can just ignore it and continue anyway.
But if you are having stability issues then you should try to move the outlet further downstream to avoid the problem. Also have a look at mesh quality in general. Any improvements in mesh quality will have a major effect on convergence. |
Fatal overflow in linear solver error. Why? | zaidun | CFX | 7 | August 11, 2016 05:59 |
Fatal overflow in linear solver | alinik | CFX | 21 | February 29, 2016 16:43 |
fatal linear solver overflow | h.mortezaee | CFX | 2 | July 3, 2015 10:35 |
2D isothermal cylinder not converging | UPengineer | OpenFOAM Running, Solving & CFD | 7 | March 13, 2014 05:17 |
time consuming of the linear solver | luckycfd | OpenFOAM Programming & Development | 3 | September 23, 2013 05:29 |
