February 26, 2008, 18:04 |
mesh from icem cfd to cfx, how?
I generated a mesh on ICEM CFD (version within ANSYS CFX-v11.0), then I save as a mesh file (model called *.uns) (File --> mesh --> save mesh as) In CFX-Pre (ANSYS CFX-v11.0 version), I start a new simulation, then I
choose "Import mesh", In "mesh format", I choose "ICEM CFD", then I browse to file "model.uns", then click, but error appears like: ERROR There was a problem importing the mesh from the requested file. The importing process reported the following problem: Unable to import mesh: File does not appear formatted as a CFX5 import file. I tried many times, with many different models, but I had the same error, as you can see. Please, show me why ? Any help, would be great ! Thanks ! |
February 26, 2008, 18:50 |
Re: mesh from icem cfd to cfx, how?
Look this post: http://www.cfd-online.com/Forum/main.cgi?read=57425
You have to select ANSYS CFX instead of Fluent_V6. *.uns is ICEM CFD format and you can't import it into CFX-pre. If you can't make *.gtm file, you can select any other supported by CFX-Pre. Hope it helps! |
February 27, 2008, 03:51 |
Hai Rogerio,
After generating the mesh(*.uns) in ICEM, goto the Output tab. Click on 'Select Solver' and choose it. Then click on 'Write Input' and choose binary instead on ASCII. Then write your Input file(*.cfx5) and import this to CFX. Regards, Subha. |
February 27, 2008, 06:58 |
"Output tab" where? On icem?
"Then click on 'Write Input'" : maybe it would be 'Write output', insīt it? |
February 27, 2008, 08:29 |
"Hai Rogerio,
After generating the mesh(*.uns) in ICEM, goto the Output tab. Click on 'Select Solver' and choose it. Then click on 'Write Input' and choose binary instead on ASCII. Then write your Input file(*.cfx5) and import this to CFX. Regards, Subha." Hi Subha, i did what u said, but i got this error message: "Error: Running ICEMCFD - CFX5 Interface Vers. 10.0.1 Error: no volume elements found.child process exited abnormally". I wonder, what did I do of wrong? I didnīt use block to make the mesh, called, test.uns. I followed exactly that you recommend to do. |
February 27, 2008, 08:41 |
Are you sure you generate a volume mesh? The error message says clearly that you haven't create volume elemets. Probably you have surface elements only. In this case you need to select the "Volume Meshing" tab in order to create it.
February 27, 2008, 09:04 |
I will try to do this!
February 27, 2008, 10:11 |
Hi Fusuion
I select the "Volume Meshing" tab in order to create the mesh, but iīve been had the same error message. Do you have another idea for correcting this problem? Thanks! |
February 27, 2008, 10:34 |
#9 |
Hai Rogerio,
1. Is your mesh tetra or hexa? 2. If hexa, did you check your blocks and assosivity? 3. Tell us how did you create you mesh (*.uns) Regards, Subha. |
February 27, 2008, 10:43 |
#10 |
Itīs hexa. I didnīt use blocks!
"2. If hexa, did you check your blocks and assosivity? ": No, because i didnīt create blocks! "3. Tell us how did you create you mesh (*.uns)": i choose hexa or hexa-dominante and I sent to compute the mesh! I choose the volume mesh tab, but when i send the file do Solver (ANSYS CFX), i found this error message, as i mentioned before! |
February 27, 2008, 19:54 |
#11 |
I created the mesh, but i didnīt use blocks. I exported to mesh.cfx5 for running on ANSYS CFX-v11.0 (CFX-Pre). Whatīs the meaning of these blocks?
February 27, 2008, 19:56 |
#12 |
Whatīs the objective of using these blocks
February 28, 2008, 03:23 |
#13 |
Hai Rogerio,
I think you should have a look on the tutorial 'Tibia' to generate pure Hexa Dominant mesh in ICEM. If you are not able to generate the output file still after following the procedure, then get back to us. Regards, Subha. |
February 28, 2008, 08:19 |
#14 |
Where is the the tutorial of 'Tibia' ?
March 1, 2008, 06:46 |
#15 |
Dear Sir/Mam
I want to know abt the ICEM CFD. Actually what's the meaning of ICEM & Detail about the CFD & please If you give certifiction in CFD than please forward all details at my email-id. Regard's naveen |
August 27, 2011, 15:05 |
Reg converting .uns file to .gtm file
#16 |
Arun raj.S
Rep Power: 14 |
Hi Rogerio Fernandes Brito,
Have u found any solution for this problem...bcoz nw i am also facing the same problem i need to know what i have to do now...your help will be highly appreciated...jus give us a detailed explanation for converting .uns to .gtm file.... |
April 16, 2016, 10:47 |
#17 |
Lianyan Zheng
Hi Rogerio,
I am reading your proplem,uh...I study CFD recently,and i have the same proplem with you. "Error: Running ICEMCFD - CFX5 Interface Vers. 15.0 Error: no volume elements found.child process exited abnormally". How did you settle it? |
April 18, 2016, 03:34 |
Dont remember
#18 |
Arun raj.S
Rep Power: 14 |
Hi Lois,
I am extremely sorry for not replying. I actually used UNIX during my MASTERs 2011. After that I am using windows platform. So I don't remember how I solved this problem. Try with some other threads |
How to export 2-D mesh from ICEM CFD for CFX | karimakhtar | ANSYS Meshing & Geometry | 13 | November 3, 2011 09:36 |
[ICEM] icem mesh to CFX 12.1 | atturh | ANSYS Meshing & Geometry | 6 | February 24, 2011 14:33 |
ICEM 12 CFD help creating volume mesh from stl | EmpError | ANSYS | 0 | November 13, 2010 06:38 |
prob while exporting icem cfd hexa mesh to fluent | mani | CFX | 4 | March 7, 2007 03:41 |
How to extrude 2D Mesh in ICEM CFD? | VSB | CFX | 7 | December 27, 2006 11:58 |
