May 17, 2016, 02:45 |
how can we import new equation in cfx?
farzad
Rep Power: 9 |
this equation is complex it is pennes thermal equation this equation about the bio heat transfer plzzzzzzzzz help me:confuse d: |
May 17, 2016, 04:00 |
Maxim
Rep Power: 12 |
write an expression.
read the documentation and do the tutorials if you don't know how. |
May 19, 2016, 10:19 |
hi agine
#3 | |
farzad
Rep Power: 9 |
it,s in jpg file tnx |
May 19, 2016, 10:49 |
Rep Power: 32 |
Your equation is missing critical information such as the meaning of the different terms, and where they come from.
Are you solving the equation in a solid domain ? Do you want to implement it as a separate equation with no interaction with the existing heat transfer model , or as an extension of the existing heat transfer model ? the former can be done using an additional variable (read documentation as suggested) while the latter can be approached using a source term with the proper linearization coefficient. Hope the above helps, |
How I could import Ansys mesh into CFX? | mahdi57 | ANSYS Meshing & Geometry | 8 | August 9, 2013 04:49 |
Import CFX def into Fluent | eric_wang | FLUENT | 0 | April 18, 2011 13:14 |
how to implement an user defined equation of state in CFX 10.0 | IvanCFD | CFX | 1 | August 16, 2009 08:28 |
equation in cfx | aleh | CFX | 0 | December 23, 2008 10:29 |
I-Radiation Equation problem with CFX Parellel | Scott | CFX | 2 | January 9, 2007 20:39 |
