May 20, 2016, 23:37 |
pressure Poisson equation
Rep Power: 11 |
Does anyone know if the pressure Poisson equation for the incompressible Navier-Stokes equations is used only with segregated solver or coupled solver too ? Thank you for your help ! |
May 21, 2016, 06:07 |
Rep Power: 143 |
CFX does not have a segregated solver. It only has a coupled solver. The equations are solved as a coupled set of momentum and pressure equations, the pressure equation is not solved as a separate poisson equation.
May 22, 2016, 13:56 |
#3 | |
Rep Power: 11 |
The poisson equation + momentum equation or continuity equation + momentum equation ? |
May 22, 2016, 21:40 |
Rep Power: 143 |
The continuity equation is combined with the momentum equations into a single matrix for solution in the coupled solver.
So I guess that means "continuity equation + momentum equation" is the correct answer. |
question regarding LES of pipe flow - pimpleFoam | Dan1788 | OpenFOAM Running, Solving & CFD | 37 | December 26, 2017 14:42 |
writing an acoustic code based on FW-H equation, have a question regarding pressure | mrshb4 | OpenFOAM Running, Solving & CFD | 3 | November 8, 2014 20:12 |
About theory:how to get the pressure equation when solving u-p simultaneously? | lzw2003 | Main CFD Forum | 8 | April 8, 2012 22:13 |
error message | cuteapathy | CFX | 14 | March 20, 2012 06:45 |
FEM pressure poisson equation (Implicit) | cfd-beginner | Main CFD Forum | 0 | August 9, 2005 13:32 |
