How can I export .res file in CFX?
I have run a axial turbine. but Now I want to export .res file. How can I export .res file in CFX? I understood that i can import .res file to Tecplot. But in CFX post(Result), I don't can see such as this type of file! In fact, I see as follows: I investigated different options. After these stages, I don't see .res file type!!! I am grateful that guide me about this case. Thanks. Best. |
In the ANSYS Solver Manager, select Tools from the Top Menu, Export Results
You get a window to select the export format of interest. |
I do the following way according to your statement: Is this way right? In third picture, I don't know that what file select in Results file(under Source). I am grateful that guide me about this case. Thanks. |
I would assume you have to chose your .res file you just created (from your simulation) as SOURCE.
At the bottom of this dialogue, you can set an OUTPUT format (I don't know which one you need for tecplot) and set a name for the file. |
