ANSYS CFX: unregular spreading of arrows at Inlet and Outlet |
June 14, 2016, 05:21 |
Sophie Yavuz
Hello everybody,
I`m using CFX the first time, so it`s completely new for me. My Problem is: I set one Inlet and Outlet Boundary for my flowsimulation. The thing I am worrying about is that the arrows, which are supposed to show you the flow direction, are not spread regular over the Inlet or Outlet. It also affects the Solutions. In a Domain with less arrows is also less or no fluid running through. Normally the massflow should be spread regular all over the Inlet or Outlet Region. Does somebody know a reason or a solution for this unregular spreading of the arrows? I hope you could understand my problem. If not, I`ll answer every question you have. Thank you for your help Greetings Aylin |
CFX FSI Fatal Error | unbanana | CFX | 0 | October 3, 2015 05:57 |
CFX Simple valve model, inlet and outlet conditions | 749604 | CFX | 24 | August 11, 2014 18:51 |
define BCs at inlet and outlet for natural ventilation simulation | jjz2013 | Main CFD Forum | 0 | January 29, 2013 15:50 |
CFX problems with supersonic inlet condition - Inlet values in CFX-Post are wrong | jannnesss | CFX | 5 | February 25, 2011 16:24 |
ATTENTION! Reliability problems in CFX 5.7 | Joseph | CFX | 14 | April 20, 2010 15:45 |
