Home > Forums > CFX
Impeller is not rotating
Old   June 15, 2016, 00:57
Default Impeller is not rotating
junwee
kumar93 is on a distinguished road
Reference pressure: 1 atm
Inlet pressure: 4360 Pa (Hydrostatic pressure)
Outlet pressure: 2657 Pa
Interface: Frozen Rotor
Impeller: 2656rpm
Hi guys,I am fresh to CFX but I have went through tutorials before carry out my project. The flow pattern is incorrect(should be looks like vortex) and I've found out the impeller is not rotating when i set it to stationary (0 rpm) and i get same result. May I know which part I did wrongly?
In fact, the outlet pressure should be higher than inlet.
kumar93 is offline   Reply With Quote
Old   June 15, 2016, 02:07
Maxim
-Maxim- is on a distinguished road
If you want your impeller to rotate, you need to do a transient simulation.
-Maxim- is offline   Reply With Quote
Old   June 15, 2016, 03:07
junwee
Hi Maxim,I am sorry if my statement is not clear enough. What I mean is although I defined impeller as solid domain and 2656 rpm, it didn't shows the correct streamline and result. Regardless of what RPM i defined, the result is still the same. In other word, the impeller is not 'rotating' to generate higher pressure and velocity.
I don't really need the impeller to rotate in animation.
Old   June 15, 2016, 03:22
ghorrocks is a jewel in the roughghorrocks is a jewel in the roughghorrocks is a jewel in the rough
Are you drawing streamlines on Velocity? That may well show no twist. If you draw them on "Velocity in stationary frame" that might show what you are thinking of.
And: why have you defined the rotor as a solid domain? It should be a region cut out of the fluid domain as there is no need to model the rotor as a solid for most cases. Have a look at the CFX tutorial examples on rotating machinery.
Finally: As your volute design appears to be poor (there is a large gap between the impeller and volute casing) I would not expect much pressure rise in this design.
Old   June 15, 2016, 03:37
junwee
Hi ghorrocks. Thanks for your reply.
what do you mean by drawing streamlines on velocity? the inlet piping is close to the eye of impeller in order to ensure the water is fully absorbed by the eye.
Do you mind sharing the tutorial examples you mentioned above? Because tutorials i went through, impeller are usually defined as a solid domain.
I am sorry to have a such poor design as this is the only educational pump that I have.
Old   June 15, 2016, 05:07
monkey1 is on a distinguished road
Maybe these two threads could help you.
They deal with similar problems:
Simulation by ansys cfx for a ceilng fan balde
Axial Fan Timestepsize
monkey1 is offline   Reply With Quote
Old   June 15, 2016, 07:41
You can choose which variable the streamline is integrated on. The default is velocity but sometimes Velocity in stn frame is appropriate.
I have never seen a tutorial example where the impeller is a solid domain. They are always regions cut out of the fluid domain. Have a look at the CFX tutorials or the links Monkey1 quoted.
Thread Tools
Trackbacks are On
Having a few problems in simulating a rotating impeller ajinsan CFX 12 February 4, 2016 17:10
Autoclave with two sets of impeller blades to hollow rotating shaft - Error in Comput bharadwaj813 Main CFD Forum 0 March 31, 2015 06:45
Rotating Impeller Naith FloEFD, FloWorks & FloTHERM 22 November 5, 2012 09:53
Mixing model with rotating impeller problem 201 CFX 10 May 14, 2010 11:59
Boundries of rotating impeller created in Gambit ? Mounir FLUENT 2 October 23, 2000 06:56
