CFX: Fan (Swirling Velocity) Boundary Condition |
July 11, 2016, 12:12 |
Rep Power: 9 |
I was wondering if there is a way to specify a fan boundary condition on a surface in CFX, similar to the one shown here for Fluent: https://www.sharcnet.ca/Software/Fluent6/html/ug/img1174.gif The most important thing for me is modeling the swirling velocities at the outlet of the fan surface. Thanks. |
July 18, 2016, 11:12 |
N/A
Rep Power: 13 |
There is a method in CFX to simulate the fan BC but different from that is in fluent. The fan should be replicated as one element thick subdomain (same for fluent also) and then define the momentum siurces equivalent to the head change across the fan. Momentum sources are of r, theta and phi....
July 18, 2016, 11:20 |
Rep Power: 9 |
Gotcha, I ended up using a momentum source. My momentum source is basically a part file that is imported into design modeler, and it is meshed as a fluid domain. Is that okay? There are multiple elements within the momentum source because my fan is pretty big.
July 19, 2016, 06:26 |
N/A
Rep Power: 13 |
You are almost there..
In the cross section doesn't matter but in thick you must have only one element. |
July 19, 2016, 07:26 |
Rep Power: 10 |
Hi lgn_aero;
I was looking a solution nearly same problem, i need to apply a rotating flow on a interface domain, i have CFX V14 and on CFX V14 you can apply mass flow rate, pressure change (both are normal to the interface area) or you can apply an expression at interface domain. I try to write an expression but couldn't figure out how to simulate a mathematical model of rotating flow using r, theta and phi... I'm very new on CFD. I'm trying to modelling a flow which moves like a screw, rotate and traslate at the same time which shown in the picture. (swirling flow?) Can you halp me about how to model it? or can you write a little sample expression? Thank you allready and sorry for my english. |
mesh file for flow over a circular cylinder | Ardalan | Main CFD Forum | 7 | December 15, 2020 13:06 |
Basic Nozzle-Expander Design | karmavatar | CFX | 20 | March 20, 2016 08:44 |
Problem with assigned inlet velocity profile as a boundary condition | Ozgur_ | FLUENT | 5 | August 25, 2015 04:58 |
desired velocity profile from fan boundary condition | mani1455 | Fluent UDF and Scheme Programming | 1 | March 5, 2015 21:59 |
RPM in Wind Turbine | Pankaj | CFX | 9 | November 23, 2009 04:05 |
