Home > Forums > CFX
Entering material properties for gas / solid phase change
Old   July 19, 2016, 09:43
Default Entering material properties for gas / solid phase change
Romain Masse
Romain_M is on a distinguished road
Hello CFX-users !
I've been throught the help and the forums, and I can't find how to enter the material properties knowing that I want to simulate phase change of Magnesium gas into solid particles ...
Do I have to enter only one material at normal T and P conditions ?
Or a solid material at normal T and P conditions and gas material at higher temperature conditions ?
I am currently using nasa format for the Cp implying that it changes with temperature instead of entering a value.
Thank you and good afternoon !
Romain
Romain_M is offline   Reply With Quote
Old   July 19, 2016, 19:52
ghorrocks is a jewel in the roughghorrocks is a jewel in the roughghorrocks is a jewel in the rough
Modelling phase change is complex. Before you look at your magnesium case, do you thoroughly understand phase change on a well studied case like water? Make sure you understand phase change in water thoroughly before starting anything else.
Old   July 20, 2016, 05:51
Romain Masse
Hello Glenn, and thank you for the answer.
I don't know about water phase change, or just a little as I read some threads and CFX help.
Anyway is there any specific tutorial about this cas ? Because the ones I found aren't really exhaustive ...
Old   July 20, 2016, 06:45
There are more tutorial examples on the ANSYS community webpage. Also ask ANSYS support for examples of the sort of phase change you want to model. They won't have much for magnesium but they will for water.
Thread Tools
Trackbacks are On
Error finding variable "THERMX" sunilpatil CFX 8 April 26, 2013 07:00
Material Properties for Sat. Liquid and Sat. Vapor Blackhawks84 FLUENT 0 September 17, 2012 19:11
Defining solid material properties query siw CFX 1 April 21, 2010 16:49
mass flow in is not equal to mass flow out saii CFX 2 September 18, 2009 08:07
CFX4.3 -build analysis form Chie Min CFX 5 July 12, 2001 23:19
