How to set the temperature on the wall , which varies each coordinate in CFX? |
August 1, 2016, 06:53 |
Alexey Ishchenko
Rep Power: 9 |
The question is this : there is a tee : two inputs and one output . attached to the wall temperature field , the temperature of each has its own coordinates . I know what can be done in Mechanical with the External Data. Help, how to do it in CFX
August 1, 2016, 08:20 |
Rep Power: 143 |
You can use CEL expressions, 1D interpolation functions, profiles, FSI, user fortran routines and more methods to set a varying temperature profile. There are lots of ways.
If you describe what sort of temperature function you are trying to impose then we might be able to help you. |
August 1, 2016, 08:36 |
Alexey Ishchenko
Rep Power: 9 |
http://www.ex.ua/512428511981
here is file object and the file with the values that should be used as a data array. |
August 1, 2016, 08:50 |
Alexey Ishchenko
Rep Power: 9 |
Please help me set these values on the boundary wall
August 1, 2016, 20:39 |
Rep Power: 143 |
Please post information on the forum. I do not follow links to strange websites.
You can attach images and files to the forum. |
August 3, 2016, 08:52 |
Down
Alexey Ishchenko
Rep Power: 9 |
?????1.xls
??????.jpg i`m download here a screen file of object and the file with the values that should be used as a data array. Please, help insert my values in my file. |
August 3, 2016, 09:15 |
question
#7 | |
Alexey Ishchenko
Rep Power: 9 |
2.jpg And how to assign a function (the wall temperature on the jig) boundary condition wall? |
Divergence in AMG solver! | marina | FLUENT | 20 | August 1, 2020 11:30 |
Natural convection in a closed domain STILL NEEDING help! | Yr0gErG | FLUENT | 4 | December 2, 2019 00:04 |
Ansys CFX problem: unexpected very high temperatures in premix laminar combustion | faizan_habib7 | CFX | 4 | February 1, 2016 17:00 |
Difficulty In Setting Boundary Conditions | Moinul Haque | CFX | 4 | November 25, 2014 17:30 |
[snappyHexMesh] determining displacement for added points | CFDnewbie147 | OpenFOAM Meshing & Mesh Conversion | 1 | October 22, 2013 09:53 |
