August 26, 2016, 14:20 |
cfx-pre
Rep Power: 10 |
hi everybody
i am working on simulating a solar chimney and i have a problem. for converging first we st boundary condition as follow: inlet: static pressure (1 atm) outlet: mass flow rate (0.05 kg/s) and i set ideal gas for flow. during the solving i monitor the mass flow at inlet but after few seconds it converge to zero where do you think i made a mistake??? thanks |
August 27, 2016, 06:41 |
Rep Power: 143 |
Have a look at your results file in CFD-Post. That should give you some clues about what is wrong.
August 27, 2016, 11:32 |
result file
Rep Power: 10 |
thanks ghorrocks
i got result and saw that the velocity vectors at inlet are toward outside and because of this problem the mass flow at inlet is zero how can i fix it??? thanks |
August 28, 2016, 06:30 |
Rep Power: 143 |
I have no idea what that image is showing. Please explain what you are doing. Labelling your images would help, also showing what you expect to get and why.
August 29, 2016, 01:31 |
Jiri
Rep Power: 13 |
Moreover I would try to set "total pressure" instead of "static pressure" at the inlet. Combination of inlet total pressure + outlet mass flow is more stable than inlet static pressure + outlet mass flow.
CEL expression in CFX pre | Jane92 | Main CFD Forum | 1 | June 3, 2016 02:48 |
Only two turbulence options available in CFX Pre | Jack001 | CFX | 5 | March 30, 2016 02:47 |
air ideal gas in CFX Pre | wangy1767 | CFX | 9 | October 1, 2012 07:55 |
CFX Pre Domains for centrifugal pump | MechKim | CFX | 1 | September 24, 2012 08:06 |
CFX 10 -pre and -post problams on Linux | Henry Liu | CFX | 3 | June 22, 2006 06:57 |
