Calculating change in energy at several test points in a geometry |
September 5, 2016, 19:50 |
Nomen Ose
Rep Power: 9 |
Hello guys I need help with collecting energy change data over time at several test points in my geometry on CFX-Pre.
I can collect data sure as pressure, density, temperature etc but I can't seem to find an energy option. Please help. Regards, |
September 6, 2016, 11:35 |
Rep Power: 32 |
What do you mean by energy ? Which kind of energy ? Thermal, kinetic, mechanical ?
Perhaps you are looking for Static Enthalpy, Total Enthalpy, or similar. Hope the above helps, |
September 6, 2016, 16:13 |
Nomen Ose
Rep Power: 9 |
The aim is to calculate the change in thermal energy of a passenger inside a bus after x amount of time
September 6, 2016, 18:14 |
Rep Power: 32 |
The change in thermal energy only should be proportional to the specific heat capacity and the temperature difference; therefore, delta U = C * (T_2 - T_1).
DPMFoam - Serious Error --particle-laden flow in simple geometric config | benz25 | OpenFOAM Running, Solving & CFD | 27 | December 19, 2017 20:47 |
Create geometry from mesh points in ICEM-CFD | David Arthur | Main CFD Forum | 3 | October 25, 2014 12:19 |
can I change the geometry file? | a.melandinos | CFX | 2 | March 8, 2002 12:57 |
Adaptive optimization of geometry | Jan Rusås | CFX | 1 | September 16, 2000 02:38 |
Why FVM for high-Re flows? | Zhong Lei | Main CFD Forum | 23 | May 14, 1999 13:22 |
