Inlet Boundary Conditions with experimental data |
September 19, 2016, 11:22 |
Rep Power: 11 |
Hello, I would like to know how "dangerous" it is to use experimental data (velocity profil) as inlet boundary conditions ? Indeed, experimental data can have slight inconsistencies between them and so they don't respect exactly the continuity equation ...
Thank you ! |
September 19, 2016, 19:17 |
Rep Power: 143 |
A simulation requires an accurate description of the boundary conditions. If you can specify it accurately enough with experimental data then that sounds good to me. But note the CFD requires the boundary conditions to be well posed and numerically stable.
Wrong flow in ratating domain problem | Sanyo | CFX | 17 | August 15, 2015 06:20 |
Low torque values on Screw Turbine | Shaun Waters | CFX | 34 | July 23, 2015 08:16 |
Setting rotating frame of referece. | RPFigueiredo | CFX | 3 | October 28, 2014 04:59 |
Radiation interface | hinca | CFX | 15 | January 26, 2014 17:11 |
inlet velocity boundary condition | murali | CFX | 5 | August 3, 2012 08:56 |
