February 17, 2001, 07:11 |
restart with a dump file
Hi, everybody,
I am running for CFX 4.1 and I want to get some help from you. I intend to use the restart file, and the geometry of this problem is different from the dump file. However, they have a same boundary dimension. I want to read the values of all variables on the boundary, How can I get the results? By the way, In the CFX-View software, the velocities and geometry of cylinder coordinates will be changed, How can I get the images such as radial and tangential velocites distribution? |
February 19, 2001, 02:55 |
Re: restart with a dump file
try to look into the $CFXDIR/extras/slvlib/single/finerestart dirctory. The README-file will tell you what to do. Hope this helps Fabian |
Display Modes | |
OpenFOAM 1.7.1 installation problem on OpenSUSE 11.3 | flakid | OpenFOAM Installation | 16 | December 28, 2010 08:48 |
[blockMesh] BlockMesh FOAM warning | gaottino | OpenFOAM Meshing & Mesh Conversion | 7 | July 19, 2010 14:11 |
OpenFOAM Install Script | ljsh | OpenFOAM Installation | 82 | October 12, 2009 11:47 |
[OpenFOAM] ParaView 33 canbt open OpenFoam file | hariya03 | ParaView | 7 | September 25, 2008 17:33 |
DecomposePar links against liblamso0 with OpenMPI | jens_klostermann | OpenFOAM Bugs | 11 | June 28, 2007 17:51 |
