April 11, 2001, 05:43 |
Setting Pressure on an Outlet Boundary
I'm currently trying to solve a (very simple?) 2 phase problem in CFX. I have a box with the air in the top half and water in the bottom half and there is a flow through the box. I'm trying to set the pressure on the outlet to be hydrostatic in the water part. This is proving to be far more difficult than it should be.
In subroutine USRBCS I use CALL GETVAR('USRBCS','P ',IVAR) and then after calling subroutine IPREC for the outlet. VARBCS(IVAR,1,INODE) = RHOW*GRAVITY*(0.52 - ZP(INODE)) where 0.52 - ZP(INODE) is the height term. I've written data to a file within this routine, I know that the IPREC gets the outlet, I calculate the correct value for pressure, but when I look at the values of P(INODE,1) across the outlet they are all zero. It's confusing me no end, can anyone help? |
April 11, 2001, 07:52 |
Re: Setting Pressure on an Outlet Boundary
Have you set IUBCSF correctly?
Gert-Jan |
April 12, 2001, 06:35 |
Richard It is not necessary to use GETVAR because the utility gives you the variable value throughout the computation domain. You can just use the IPREC to get the variable pointer(IPT) on boundaries. These pointer help you get variable location you desired.
ex. P(ipt(i),iphase) = roh * zc(ipt(i)) try it. Darcy. |
simple model, difficult outlet | Eric | CFX | 7 | May 23, 2014 08:13 |
Static pressure boundary condition at outlet | jennz | CFX | 4 | February 11, 2014 03:29 |
Setting Pressure outlet boundary for simulation of Radial impeller | Mukund Pondkule | Main CFD Forum | 1 | April 5, 2011 09:24 |
Using pressure outlet BC | Shreyansh | FLUENT | 0 | November 5, 2010 14:57 |
Turbulent intensity for pressure Outlet Boundary condition | Mohsin | FLUENT | 1 | April 30, 2010 10:36 |
