Home > Forums > CFX
Periodic boundaries in CFX-Meshbuild
Old   December 2, 1999, 14:07
Default Periodic boundaries in CFX-Meshbuild
Gert-Jan van der Gulik
Hi all,
I want to create a certain geometry with several periodic boundaries in the old software package CFX Meshbuild. According to the CFX-Community pages I have to define USER2D-patches with meaningfull names. Then I have to run CFX-Meshimport that will convert these patches into periodic or inter-block-boundaries. However, this procedure doesn't work: the conversion is not obtained. Does any one have experience with this procedure and would like to share some hints and tips?
Old   December 7, 1999, 08:10
Default Re: Periodic boundaries in CFX-Meshbuild
Erik Torbergsen
Hi Gert-Jan.
The way I have solved multiple periodic boundaries, is to specify everything in the command file. It could be done quite easily like this:
>>CREATE PATCH
PATCH NAME 'P1'
BLOCK NAME 'XXX'
PATCH TYPE 'INTER BLOCK BOUNDARY'
LOW J
>>CREATE PATCH
PATCH NAME 'P2'
BLOCK NAME 'XXX'
HIGH J
>>GLUE PATCHES
FIRST PATCH NAME 'P1'
SECOND PATCH NAME 'P2'
ORIENTATION CHANGE 'HIGH I' 'HIGH J' 'HIGH K'
Erik Torbergsen
Old   December 10, 1999, 11:54
Jan Rusås
Hi Gert-Jan,
You really have to be more specific about your problem, is it in cylindrical coordinates? , axi-symmetrical ?, etc. I would also help if you could be a more specific about where the conversion goes wrong, is there an error message or what?
If you are going to include radiation it is very difficult to include the periodic boundaries in the command file, except if you have a parallel version. I also believe that the solution with the user-2d patches is a hint for Build, I have not checked it. I know the solution for meshbuild, if your problem is in cylindrical coordinates and axi-symmetric. You should define the periodic boundaries as symmetry planes, run it through mesh-import. When you run the job you should include the object file axisymm.o, you can find it in the extras library. The symmetry planes in the circumferential direction is then treated as periodic boundaries. If this is not the clue for your problem then please be more specific.
Regards Jan Rusås
Thread Tools
Trackbacks are On
Udf - Periodic Boundaries Erny Fluent UDF and Scheme Programming 2 July 7, 2013 14:22
CGNS import in fluent - periodic boundaries. Bjarne Børresen FLUENT 2 April 25, 2013 11:12
Periodic boundaries in Floworks SvG FloEFD, FloWorks & FloTHERM 1 March 17, 2009 06:53
roto-translational Periodic BC in CFX Ivandp CFX 12 December 8, 2008 10:51
periodic boundaries and pressure correction Vladimir Fuka Main CFD Forum 0 January 16, 2006 08:50
