Home > Forums > CFX
areas of no flow
Old   December 15, 1999, 08:39
Default areas of no flow
Eve Chapper
I am trying to create an area of no flow within a domain using CFX4.2 Build. I am investigating two approaches. The first is to define a solid area within the domain as a 3D solid patch. This has not been successful in creating an area of no flow. The second method is to subtract a solid from the domain for which I need a method. Any help is very much appreciated. Eve.
Old   December 16, 1999, 08:02
Default Re: areas of no flow
jy
Hello, I think you need to create the solids only where you will have a mesh. Then the surfaces will be walls, symmetry, inlet, outlets... Where you will make no calculation it not interesting to discretize (mesh). jy
Thread Tools
Trackbacks are On
Flow meter Design CD adapco Group Marketing CD-adapco 3 June 21, 2011 08:33
mass flow in is not equal to mass flow out saii CFX 2 September 18, 2009 08:07
What is the difference between liquid reactive flow and gas reactive flow? James Main CFD Forum 6 May 15, 2009 12:14
transform navier-stokes eq. to euler-eq. pxyz Main CFD Forum 37 July 7, 2006 08:42
Plug Flow Franck Main CFD Forum 3 September 4, 2003 05:57
