Looking for a commerical software to model free surface
Old   April 30, 2000, 23:59
Default Looking for a commerical software to model free surface
Michel Boufadel
Hi everybody,
As you can tell from my question I am new to this field. I am looking to buy (get licence) a software that can model the following problem 1) Put water in a flask 2) Shake the flask to and fro periodically along one direction (using a shaker).
Note that free surface is present. Ignore turbulence at this stage.
Regards,
Michel
Michel C. Boufadel, Ph.D. Assistant Professor Environmental Engineering Temple University
Old   May 1, 2000, 00:08
Default Re: Looking for a commerical software to model free surface
turboguy
My recommendation is 'commet'
please visit the comment web page, you can catch the strong capability of commet including the free surface flow.
regards,
turboguy
http://www.iccm.de
regards,
Old   May 7, 2000, 08:10
LI Xinfeng
I think the best free surface is flow3d,of course the cfx4.3 is a good choice.
Old   June 11, 2000, 12:58
turboguy
I do not agree with your comment. In case of flow-3d,mesh generation is very simple. the CPU time also very fast. But the numerical accuracy is not good.
CFX4.x is just calculate the free surface and used VOF model. It could not calculate the heat transfer between light fluid and heavy fluid of VOF model. It also can not solve the compressible effect in free surface.
Anyway, 'COMET' in the best commercial CFD code till now I have been tried.
The first is ' COMET' 2nd is 'STAR-CD' 3rd is 'Flow-3D'
turboguy.
Old   July 11, 2000, 23:54
joecfd
I'm not sure about comet, but flow3d is based on well-established free-surface tracking algorithms which are quite accurate. See Hirt and Nicholls in JFM, 1980 I think. There have been many improvements to these algorithms over the years, in particular by Kothe and co-workers at Los Alamos.
Many people have had a lot of success with these methods, especially for mold filling and water/air flows for example.
Real VOF, by real VOF I mean with a geometric reconstruction of the free surface, is generally the best approach for transient problems. What exactly does this comet do? If it's some sort of sophisticated advection scheme, I'd be suprised if it performed very well in real world situations. If it uses a moving mesh strategy then one is probably limited by the topology of the free surface (i.e. it can't do overturning waves).
I do agree with you that CFX-4 is not optimal for free surface flows.
Free surface or Mixture Model ? Hervé CFX 10 December 29, 2014 13:29
Water subcooled boiling Attesz CFX 7 January 5, 2013 03:32
VOF and Free surface model...are they same? Kushagra CFX 1 November 14, 2008 12:36
how to model a free surface lr FLUENT 5 December 8, 2000 07:51
free surface model of pelton turbine bucket Mark Jones Main CFD Forum 0 April 10, 2000 08:20
