-   -   implementing boundary conditions (http://www.cfd-online.com/Forums/cfx/18314-implementing-boundary-conditions.html)
Andreas Abdon February 5, 2000 09:52
Hello everybody!
I'm implementing boundary conditions on a user scalar equation in user fortran subroutine USRSRC. I want to assign the scalar a value in the near wall cells. The manual recommends the following procedure:
SP=-c SU=c*value AM=0 for all faces
where c is "set equal to approximately the maximum flux in the CV.. .. to stop potential errors due to the Rhie-Chow terms." (quote). I have tried this approach and also different constant values of c and found that it may distort the solution seriously, especially when the flux (velocity) is close to zero. Does anybody have a recommendation how to proceed? Is a large (1.0E10) value of c "safe" to use?
Greetings
Andreas Abdon
Div. Heat Transfer Lund Institute of Technology Box 118 22100 Lund Sweden
Andreas Abdon March 14, 2000 14:00
Re: implementing boundary conditions
I'm stuck!
** Does ANYBODY have any info on this matter, please help! **
Even if you haven't come across these problems when implementing boundary conditions I would be grateful if you let me know how you did it. I have traced the problem to one of my equations, it's a diffusion eq. with NO CONVECTION. I have tried different c values and the high ones (like 1e10) gives a reasonable solution but slows down convergence seriously. A low value gives a very good convergence rate (final residual levels as for c=1e10) but the solution is not very good.
Andreas (...nervous breakdown coming soon)
Andreas Abdon March 15, 2000 14:20
----> I FOUND IT! <------
Don't use AM(NCELL,0,IPHASE) when putting AM=0 for all six facial components! You have to loop over each individual face: AM(NCELL,1,IPHASE)=0, AM(NCELL,2,IPHASE)=0,AM(NCELL,3,IPHASE)=0, and so on....
Doing this, the solution is the same for c=1.0 nd c=1.0e10, i.e. dependence of c value is eliminated.
Cheers
Andreas
