SOURCE DIMENSIONS
Old   March 7, 2000, 08:50
Default SOURCE DIMENSIONS
Andreas Abdon
Does anybody know which dimensions CFX is using for the source terms of the momentum and scalar equations in CYLINDRICAL coordinates? I guess it should be the same as for cartesian coord. but I want to be sure. I have seen that some other codes change their dimensions when they change coordinate system (usually a multiplication by r-coordinate).
Greetings
Andreas
Old   March 13, 2000, 10:51
Default Re: SOURCE DIMENSIONS
Sascha Becker
If you are checking the basic equations you see that they have an unsteady term independend of the coordinate and a source on the RHS. By calculating the dimensions of one term you may get the correct dimension for the source even when you are using cylindrical coordinates.
---> The dimensions are still the same if you are not using sources changing with direction....
S.
[swak4Foam] swak4foam building problem GGerber OpenFOAM Community Contributions 54 April 24, 2015 16:02
pisoFoam compiling error with OF 1.7.1 on MAC OSX Greg Givogue OpenFOAM Programming & Development 3 March 4, 2011 17:18
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 19:08
DxFoam reader update hjasak OpenFOAM Post-Processing 69 April 24, 2008 01:24
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 17:51
