CFX and Reacting Porous Media
I haven't used CFX but I'd like to know whether you can model reacting porous media using CFX!? If so, is it a standard model option, or would you have to implement it using user subroutines?? In this case I expect that you would have to solve for fluid flow, continuity and at least solid continuity (to determine porosity evolution) and either a composite fluid/solid energy equation or separate fluid & solid energy equations. Thanks Greg |
Re: CFX and Reacting Porous Media
I have even used CFX4 to simulate the heat exchange tubes as porous. The results is agreement withe experiments. The porous is a standard model,but you must set the resistance and other parameters,you maybe implement it using user subroutines.
