Home > Forums > CFX
unmatched boundary
Old   April 10, 2000, 10:20
Default unmatched boundary
Li Fahong
I created a geometry with cfx-build in which a pair of unmatched boundaries was set. The problem was when I viewed the geometry with cfx-visualise, there were some lines displayed in the unmatched boundary. Because unmatched boundary is a kind of inter-block boundary, it should not displayed in cfx-visualise according to my understanding of cfx. My question is whether it's possible to eliminate the lines on the unmatched boundary?
Thanks!
Old   April 10, 2000, 20:08
Default Re: unmatched boundary
Under "Edit Graphics" you can select "Geometry Outline". You can turn the lines off there. It will remove the lines from the entire geometry, not just the unmatched boundary though.
Glenn
Old   April 10, 2000, 20:22
Hyun S. Lee
Hello?
One suspicious thing to be noted here is, "unmatched patch has small gap between blocks!!!", but it should be minimal not to shown in postprocessor. I think Glenn Horrocks' answer help you but in my case I made mistakes with gap size.
criterion in VISUALISE < thickness < criterion in BUILD
Hyun S. Lee
Old   April 10, 2000, 20:24
Default errata
Hyun S. Lee
criterion in BUILD for same point < thickness < criterion in VISUALISE for same point
Thread Tools
Trackbacks are On
Wind turbine simulation Saturn CFX 45 February 8, 2016 05:42
Implementation of boundary conditions for FVM Tom Main CFD Forum 7 August 26, 2014 05:58
transient simulation of a rotating rectangle icesniffer CFX 1 August 8, 2009 07:25
Boundary conditions? Tom Main CFD Forum 0 November 5, 2002 02:54
Boundary Conditions Jan Ramboer Main CFD Forum 11 August 16, 1999 08:59
