node-locked license file
I use a node-locked license file, how should I run cfx43?
When I start cfx and run Enviroment,CFX-Build and CFX-Analyse, the message window shows "/cygnus/cygwin-b20/H-i586-cygwin32/bin/bash.exe: G:/CFX/CFX-4.3/bin/runbuild4: No such file or directory" (G: is my installation dir) |
Re: node-locked license file
You try out this command line, from the window of cfx4.3,Click on tools and then on command line after that you use the following command
mount `G:/"/cygnus/cygwin-b20/H-i586-cygwin32/bin/' bin then press return |
Dear Sudarshan,
Thanks for your help. There's still some problem. Having entered the command you told me, the command interface said that, Warning: bin does not exist! mount failed:Device or resource busy Is the command you told me spells right? I've tried various ways. I'm waiting for your reply. Thanks a lot! |
