January 4, 2001, 11:34 |
Mesh coordinates
I am using CFX Build 4.3 to create a scroll casing geometry and mesh for small water turbine application. While Meshing, there doesn't seem to be any control over the assigning the i,j,k coordinates(well, at least I couldn't find it!). I have divided the scroll into 5 arbritrary blocks (think of PIE chart!) for ease of meshing. Problem occurs when I want to provide initial guess in TASCflow (or TASCtool) with covariant grid aligned velocity values. The different blocks have different i,j assignments i.e. in one block, the i values are along the circumference while in another it is along the radius. k is OK because it's along the axis of the machine for all the blocks. Can you please help? Thanks Drona |
January 5, 2001, 10:59 |
Re: Mesh coordinates
Hi Drona,
you can use the velocity components in cylindrical co-ordinates for the initial guess. Alternatively you can use the turbo-specific initial guess. Cheers OLAF |
Display Modes | |
[ICEM] Hexa mesh, curve mesh setup, bunching law | Anorky | ANSYS Meshing & Geometry | 4 | November 12, 2014 01:27 |
[snappyHexMesh] non-smooth mesh | Svensson | OpenFOAM Meshing & Mesh Conversion | 11 | January 18, 2012 10:13 |
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! | sc298 | OpenFOAM Meshing & Mesh Conversion | 2 | March 27, 2011 22:11 |
[snappyHexMesh] external flow with snappyHexMesh | chelvistero | OpenFOAM Meshing & Mesh Conversion | 11 | January 15, 2010 20:43 |
Icemcfd 11: Loss of mesh from surface mesh option? | Joe | CFX | 2 | March 26, 2007 19:10 |
