curve list
Old   April 26, 2001, 11:35
Default curve list
ganeshram krishnamoorthy
hello, i am a new user for cfx.when i am creating the mesh for the pipeline, i need to fill the curve list column.that is when extruding the curve to create a closed parametric surface using a translation vector of <0 0 4>.if i click the curve list with left mouse button, it should show the list with curves and points and all.also it is showing.from that list i have to select circular curve.but i cannot able to select like this.if i select the curve, it is showing error reprted by asm.if anybody knows this please let me know this.that will be helpful for me in my project.
with regards,
ganeshram.
[swak4Foam] swak4foam building problem GGerber OpenFOAM Community Contributions 54 April 24, 2015 16:02
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 19:08
DxFoam reader update hjasak OpenFOAM Post-Processing 69 April 24, 2008 01:24
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 17:51
CFX4.3 -build analysis form Chie Min CFX 5 July 12, 2001 23:19
