Geometry of straight pipe
Old   June 8, 2001, 11:20
Default Geometry of straight pipe
TUM
Hello I have problems about how to create the straight pipe with slope 1.19 degree. I do not understand about the axis that i must input the coordinate in the axis block. Please suggest the way to create this model. I just study CFX-5 for one week. Thank you
Old   June 10, 2001, 11:37
Default Re: Geometry of straight pipe
Dan Williams
If I had to do this I'd create a circle, rotate it by 1.19 degrees, and then extrude the circle the desired length along a direction vector which gives you a 1.19 degree slope.
Maybe you tried this already?
Dan.
Old   July 16, 2001, 05:36
aoyi
I have a similar problem like that of TUM. Dan suggests that you create a circle and extrude. How do you do this???
I can only extrude a surface. Further, I am unable to create surface edges from a circle because, by defualt the surace should have at least 3 edges from 3 curves.
All i did was to rotate a point on XY plane 4 times in oder to create a circle(according to example 2 of Build). This worked but is there a shorter method?
aoyi
aon a circle beneed to re
Old   July 16, 2001, 06:32
janyatoyo
how do you extrude a circle?
janyatoto
Old   July 16, 2001, 21:15
Dan Williams
You can create a curve which is a circle by simply rotating a point about a center. I think it's under Create->Curve->Revolve.
After that you need to rotate the circle by the desired angle. Transform->Rotate (or something like that), then create a surface by extruding along a direction vector. I think it's under Create->Surface->Extrude.
You'll need to add end surfaces to enclose the geometry so that you can make a b-rep. I'd just use trimmed surfaces for these.
Also, be careful if you are using CFX-5 before version 5.4. Before that the surface mesher could not mesh periodic (closed) surfaces. If that's the case then you'll need to split the original circle into two pieces.
Dan.
Old   July 17, 2001, 07:09
aoyi
Hi Dan,
Thanks for responding. For you to create a surface in cfx4.3,(Build) by default you need at least 3 edges, as i said earlier. It was not clear from your contribution how one can do this from a CIRCLE. tHAT IS IF YOU DO NOT STEP BY STEP rotate a point the create curve...revolve thing.
Under which menu option (in cfx4.3 build) do you add end surfaces?
Old   July 18, 2001, 11:12
tum
i have been already to create circle>revolve... After that i exclude the surface of that circle to be the straight. Thank you
Old   July 18, 2001, 20:33
Dan Williams
Sorry, I've never done this in CFX-4, so I'm not sure what the procedure would be. The original post was regarding CFX-5.
Dan.
[DesignModeler] DesignModeler Pipe within pipe shields ANSYS Meshing & Geometry 13 November 25, 2018 22:14
[GAMBIT] meshing in GAMBIT, a flow through a pipe having complex inflow geometry mazhar1613 ANSYS Meshing & Geometry 1 January 11, 2012 23:18
calculation of thrust thrugh a pipe with CD nozzle izhar Main CFD Forum 0 February 28, 2009 09:22
How to creat the geometry of a tapered pipe? Lee Siemens 2 September 1, 2003 10:36
How to model air filter in the straight pipe? Richard FLUENT 0 March 18, 2002 07:13
