Home > Forums > CFX
Combustion in a sphere
Old   June 22, 2001, 13:28
Default Combustion in a sphere
Caz
I am constructing a spherical vessel in which I will simulate combustion of methane and air (single phase). Ignition of the gas will be induced by raising the central spherical cell temperature to approx. 1100K.
So, my question is - can I use build where the north and south poles will cause possible problems for mesh analysis?
Do you know a way around these N & S poles occurring?
I am having major problems running meshbuild as it keeps crashing, and therefore prefer to use BUILD.
regards Caz
Old   June 22, 2001, 21:21
Default Re: Combustion in a sphere
Robin Steed
Are you referring to CFX4-Build or CFX5-Build?
If you are referring to cfx5, you can reparameterize the surface with the following steps:
i) break the sphere into octants by selecting the surfaces and using the Edit > Surface > Break command.
ii) use Create > Surface > Composite, selecting one quadrant at a time.
The composite surface function can be used on one or more surfaces (in this case you want one) and creates new surface parameterization by rotating the view and projecting a regular grid pattern over the surface. The unstructured mesher will have no difficulty with this surfaces parameterization.
Upgrades in CFX-5.5 will make this much less problematic.
If you are using CFX-4, you will have to break your sphere into an O-grid (ie a square in the center with a block on each side expanding out to the surface.)
Robin
Thread Tools
Trackbacks are On
Modelling Combustion in Porous Zone tanjinjack FLUENT 1 August 31, 2015 04:56
hydrocarbon gases + Boron particle combustion nileshjrane OpenFOAM 1 December 13, 2010 07:20
Hydrogen Air combustion in a combustion chamber popi CFX 7 July 11, 2007 18:40
Need Similar Combustion Tutorial as my model Arnab CD-adapco 0 May 24, 2005 18:23
meshing F1 front wing Steve FLUENT 0 April 17, 2003 12:37
